Author Topic: Porous Casing  (Read 4712 times)
Offline lorazepam
  • Almost ready for suspenders
Porous Casing
« on: June 13, 2015, 08:09:03 PM »
Has anyone heard of this? I had weeping at what looked to be the clutch push rod seal, and had the bike back at the dealer for warranty replacement. The head mechanic, Aaron said it was not the seal leaking, but the fluid was coming from the case next to where the bolt that holds the pushrod arm is located. they took a lot of pictures, and are going to send them to Italy, and hopefully get a new rear case for my transmission.
I have never heard of this before, but Aaron is a good mechanic, and has been wrenching on MG and BMW for several years. I did get the bike back until something is heard from Italy, and they decide what to do.
Offline Johncolleary
Re: Porous Casing
« Reply #1 on: June 13, 2015, 08:19:23 PM »
There was a recall on early 2000s Aprilias due to some having the oil tanks porous and would just ooze oil through the sides of the tank.
2013 Stelvio NTX
2014 Triumph Tiger 800
2024 Honda Transalp
2023 Kawasaki KLX300
Offline Kev m
Re: Porous Casing
« Reply #2 on: June 13, 2015, 08:21:31 PM »
A few of years ago a board member (who hasn't posted in a year or two, but into whom I ran last summer) had a porous engine case on a V7 Classic.
Sadly, it took them MONTHS, but they did get it replaced and it has been fine since.
« Last Edit: June 13, 2015, 08:23:04 PM by Kev m »
Offline TDF
Re: Porous Casing
« Reply #3 on: June 13, 2015, 08:31:37 PM »
Have seen porous cases on Ural's for certain.  Situation normal for them though.  A real bear to keep clean.
TDF
2000 V11 Sport
2000 V11 Quota
2002 MV Agusta F4 750
2000 KTM 640 Duke II
1966 Ducati Sebring 350
1965 Ducati Bronco 125
1958 MDS Super Dart 70
1966 Honda CL77
1949 Ariel VB 600
1983 Husqvarna WR430
1973 Suzuki TS125
68 & 73 CT90's
and the list goes on and on
Online scra99tch
Re: Porous Casing
« Reply #4 on: June 13, 2015, 10:10:49 PM »
Had one on an intake, probably caused the PO to sell the bike.  It was right behind the flange hole and you could only tell that it was there becuase of soot from it coughing.  JB weld and a reamer took care of it.
2007 California Vintage
Online sign216
Re: Porous Casing
« Reply #5 on: June 14, 2015, 06:43:50 AM »
Lorazpam,
I've heard of this before on a Guzzi 750, but it was the rear drive casting that was porous and leaked.  A bear to track down, since it's "not the usual suspect."
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline Matt Story
  • Flint, MI
Re: Porous Casing
« Reply #6 on: June 14, 2015, 11:19:15 AM »
I work for a company that builds assembly automation for automotive engines and transmissions.  It is common to leak test every aluminum case before assembly.  It is often done in a dunk tank.  Cases that need better quality are filled with helium and contained in a high vacuum while sniffing electronically for helium leaks.
So yes, but porous castings exist.  Maybe Aprilia should have a tighter quality control.
On a side note, it's impressive that the results of many (all?) such tests conducted during assembly are tracked throughout the assembly process, tied to the final assembly's serial number and stored through the life of the product.
Matt
« Last Edit: June 14, 2015, 11:19:44 AM by Matt Story »
'75 850T - First & only owner
'77 Honda CB750 Supersport
'02 BMW R1150RT
Flint, MI
Offline John in PA
  • ML & me
Re: Porous Casing
« Reply #7 on: June 14, 2015, 11:36:38 AM »
Wasn't this  big problem for the classic Brit-bikes before the demise of the original British motorcycle industry? (Current Triumphs obviously excepted)
John Wells
Hollidaysburg, PA
Buncha Guzzi's
Re: Porous Casing
« Reply #8 on: June 14, 2015, 01:28:06 PM »
Porous castings can be sealed, but I guess if you're going to disassemble everything to seal it by vacuum impregnation, you might as well just replace the casting with one that isn't porous.
Offline jbell
  • Some progress
Re: Porous Casing
« Reply #9 on: June 15, 2015, 04:41:27 PM »
Many years ago my bike was weeping oil through one of the side cases.  After a thorough cleaning of the inside, I copper-coated it and never had a problem again with it.
'76 Guzzi T3   Future project
'78 Guzzi G5  Current project
'81 Guzzi G5  Organ donor
'92 BMW K75RT  On the road
