Author Topic: Horrors in My Bellhousing!!  (Read 114170 times)
Re: Horrors in My Bellhousing!!
« Reply #30 on: June 14, 2015, 11:12:55 PM »
  Does your dog know that you talk about him that way?
Offline Phang
« Reply #31 on: June 14, 2015, 11:15:45 PM »
The clutch centering tool is not needed as Pete said.
We used a different approach. By measuring the inner diameter of the clutch cover and the OD of the friction plate hub, we worked out the gap as shown in the pic.
Bolt on the cover loosely, use a suitable size rod to go around the gap and torque it up after that.
The gear box (transmission) just "slips back in like pushing a greasy stick up a dog's bum"  :grin:
2000 V11 Sport (Green)
1973 V7 Sport (Green)
Offline smdl
« Reply #32 on: June 14, 2015, 11:21:05 PM »
Thanks, Phang!  No offense, but I really wouldn't want to be a dog down in the southern hemisphere!   :grin:
Shaun
'61 Galletto
'74 Eldorado Civilian
'22 V85TT Guardia D'Onore
'24 Stelvio
Offline Phang
« Reply #33 on: June 14, 2015, 11:54:13 PM »
Shaun
No, we don't shaft a stick in a dog's bum like the aussie, we cook them in curry or sweet and sour sauce  :food:
Offline smdl
« Reply #34 on: June 15, 2015, 12:10:50 AM »
Still feeling a little sorry for the canine contingent down there!   :grin:
Cheers,
Shaun
« Last Edit: June 15, 2015, 12:11:35 AM by smdl »
'61 Galletto
'24 Stelvio
Offline dan_s
    • http://www.world-designs.co.uk/forum/member.php?u=128
« Reply #35 on: June 15, 2015, 04:40:45 AM »
With the tonti big blocks you can stick an endoscope/borescope through the timing hole and starter opening and look for loose bits in the bell housing. Can you do that with the stelvio?
« Reply #36 on: June 15, 2015, 05:07:31 AM »
Yes, in fact it's even easier because there is a huge great slot in the bottom of the bell housing, (Out of which a host of shit will of fallen.) that you can stick a boroscope up.mat the end of the day though we have bits of busted spring and a mullah'd  starter motor. Whatever causes that sort of damage isn't going to simply 'Vanish' the problem if you make sure you get the bits out.
Unfortunately the clutch is 'Donald Ducked' and the only way to deal with it is take stuff apart and fix it.
Offline Stevex
« Reply #37 on: June 15, 2015, 01:26:31 PM »
That way the box just slips back in like pushing a greasy stick up a dog's bum.
I do hope that's not the voice of experience    :laugh:
« Reply #38 on: June 15, 2015, 03:31:17 PM »
Hoo boy, this sounds like it's going to be fun.  Good thing I have lots of spare time to work on projects like this.   :rolleyes:
 :grin:
Cheers,
Shaun
Well, you certainly do have a positive, cheerful attitude about it.
If my 3-year-old new $15,000 bike had puked its guts all over the place requiring a complete teardown, and there was no warranty coverage, I would probably be calm and collected too, but in another way.
I'd calmly tow it to a dealer, calmly ask them to fix it, calmly pay the bill, and calmly ask them after it was fixed if I could leave the worthless piece of unreliable crap at their shop while the 7 days of eBay ticked down, starting with a $.99 bid and no reserve ...
I've already told my Stelvio that, and it's been behaving well.   Got 2000 miles of riding to do in the next couple weeks, and I'm expecting quality performance, not China Syndrome internal metallurgy failures.
Good luck!
Offline nick949
    • Nick Adams Writing
« Reply #39 on: June 15, 2015, 03:44:07 PM »
sorry to hear of your woes Shaun.  Dan gave me the bug....im in Espanola heading for the Soo and point north. Eldo, of course.
Offline pyoungbl
« Reply #40 on: June 15, 2015, 03:49:12 PM »
Shaun; for what it's worth, last Saturday I helped a friend pull the swingarm on a Norge so we could check the bearings.  The whole job (to include lubing the drive shaft splines and shock linkage needle bearings) took just 3 hours start to finish.  We could have done it quicker but Mark only had a minimal set of tools.  Some "T" handle allen wrenches and socket extensions would have been handy.
Peter Y.
'13 V7 Special (red/white)
Offline smdl
« Reply #41 on: June 15, 2015, 06:58:29 PM »
Have fun, Nick.  I now know what a great bike your Eldo is!  By the way, I did raise the needles on my Eldo today, and it definitely liked it.  I have some jets on the way, and will have some more fun with it.  Not too much, though, as I think I have a u-joint issue, and I want to get the gearbox out to seal the back on the engine.  All good fun!
Shaun
'61 Galletto
'24 Stelvio
Offline smdl
« Reply #42 on: June 15, 2015, 07:00:19 PM »
Lannis and Peter, thanks for the well-wishes and the information.  Seems I have lots of Guzzi work to do, but it's not the end of the world.  I will persevere!
Cheers,
Shaun
'61 Galletto
'24 Stelvio
Offline smdl
« Reply #43 on: August 16, 2015, 11:16:52 AM »
HI, folks.
I'm digging in to change the clutch, and thought I would tap the knowledge and experience of WG.  Swingarm and shock are out (latter to be replaced by a lowered Matris unit), and I am digging into the engine mounts, wiring, etc..  A couple of questions that I haven't seen answers for in the manual (yet):
1.   Does anyone know what gaskets I am likely to need to replace?  I'm thinking intake manifolds, exhaust head pipes, etc.  I don't know if any of these modern items are considered reusable.
2.    What retains the driveshaft/u-joint in the gearbox?  I'm sure I will find the answer to this shortly, but it never hurts to ask!
Cheers,
Shaun
'61 Galletto
'24 Stelvio
« Reply #44 on: August 16, 2015, 11:47:16 AM »
I can't think of any gaskets you need to replace to do a clutch?
Offline Jurgen
« Reply #45 on: August 16, 2015, 11:59:00 AM »
Thanks, Pete.  You do, erm, have a way with words that is quite unlike anyone else I have encountered.  Hope you never change.   :grin:
Shaun  Shaun: I really admire your equanimity in the face of this disaster.  I'd be fuming after the second starter removal!  Good luck!  Jurgen
Jurgen
Offline smdl
« Reply #46 on: August 16, 2015, 12:06:10 PM »
Hi, Pete.
First time doing this on a modern CARC bike, so don't know what to expect.  For example, the manual indicates that I need to remove the exhaust system (which I am about to do) in order to drop the engine, and I don't know if that means that the series of exhaust gaskets can be re-used, or if it expected to re-use these.  For example:
http://www.mgcycle.com/index.php?main_page=product_info&cPath=26&products_id=4561
http://www.mgcycle.com/index.php?main_page=product_info&cPath=26&products_id=3116
Same with the intake manifold gaskets.  You had indicated that I could just disconnect the manifolds at the heads, and leave them in the air box (thanks for that tip).  Wondered if I should plan to replace the intake manifold gaskets?
Overall, I am trying to put together a list of parts to order, and am trying to be complete as possible as every additional order takes at least a week to arrive.
Thanks for the help -- it's very much appreciated!
Shaun
« Last Edit: August 16, 2015, 12:13:49 PM by smdl »
'61 Galletto
'24 Stelvio
« Reply #47 on: August 16, 2015, 12:06:51 PM »
HI, folks.
Cheers,
Shaun
Glad to see that you are carrying on.
Just as an encouragement, my Stelvio has done the 2500 miles of running around the country over the past few months that I said I would, and is running like a Swiss watch from just over the border from Italy.
If you can hang in there, you might go 150,000 miles without ANY more problems ... it's happened before!!
Offline smdl
« Reply #48 on: August 16, 2015, 12:08:31 PM »
Thanks, Jurgen.  I won't say that I haven't invented a few new words in the process  :grin:, but it's fortunate that I enjoy working on motorcycles!
Cheers.
Shaun
'61 Galletto
'24 Stelvio
Offline smdl
« Reply #49 on: August 16, 2015, 12:12:49 PM »
Cheers.
Shaun
Thanks, Lannis.  Fingers crossed, for sure.  I will say that these modern bikes, while wonderful in so many ways, really make me appreciate my old Eldo from a mechanical/electrical simplicity perspective.  I had that one apart for a u-joint change a couple of weeks ago, and there was a lot less to worry about!  Still, the new bikes are fun, too, especially with the ability to tweak with fun tools, like Guzzidiag!
All good fun!
Shaun
'61 Galletto
'24 Stelvio
« Reply #50 on: August 16, 2015, 12:13:04 PM »
With care, no gaskets should be needed. I damaged a gasket in the Y pipe when I jammed the header pipe in poorly.
The driveshaft is held to the output shaft with a spring loaded clip. A good 'soft'  rod to tap/pry it off will help.
Offline smdl
« Reply #51 on: August 16, 2015, 12:19:18 PM »
Thanks, Wayne.  So, just to confirm, it's not a clip that I need to remove and then slide the driveshaft out?  I just need to lightly persuade the driveshaft to overcome the tension of the spring-loaded clip?
Thanks,
Shaun
'61 Galletto
'24 Stelvio
Offline nick949
« Reply #52 on: August 16, 2015, 01:15:05 PM »
Go for it Shaun - we're rooting for you. :popcorn:   I won't even be disappointed if you ride the Stelvio to Lavigne after all your efforts :thumb: :boozing:
Nick
« Reply #53 on: August 16, 2015, 01:27:31 PM »
Yes, though it may need a bit more than 'light' persuading.
Of course grease all splines and swingarm bearings when reassembling.
Offline smdl
« Reply #54 on: August 16, 2015, 01:40:46 PM »
Nick
Thanks, Nick!  Not a chance!  I'll be happy to have the parts on order while we are in Lavigne.  Then, I'll be even happier if I can figure out how to get Humpty-Dumpty back together again!
Cheers,
Shaun
'61 Galletto
'24 Stelvio
Offline pyoungbl
« Reply #55 on: August 16, 2015, 01:46:42 PM »
Here's a photo of the inside of the splined Cardan shaft...see the clip?
It takes a right smart smack to pop the joint off the output shaft.  You can also try pushing a wedge between the end of the output shaft and the joint.
Offline smdl
« Reply #56 on: August 16, 2015, 02:12:07 PM »
Great, thanks, Wayne.
Shaun
'61 Galletto
'24 Stelvio
Offline smdl
« Reply #57 on: August 16, 2015, 02:13:53 PM »
Yep, very helpful.  Thanks again, all.
I might not be very fast at this, but with all you guys helping, I'll make it eventually!   :bow:
Cheers,
Shaun
'61 Galletto
'24 Stelvio
« Reply #58 on: August 16, 2015, 04:00:23 PM »
Hi, Pete.
Shaun
Sorry, for some reason I thought this was a V7 :shocked: I'll go back and have a squizz and reacquaint my self with the thread.
If it's a Stelvio it's a right frontbottom of a job.
« Last Edit: August 16, 2015, 04:16:42 PM by Vasco DG »
« Reply #59 on: August 16, 2015, 04:19:18 PM »
See, the front calipers stay on. A huge time saving right there.
:violent1:
