Author Topic: Sticky switch  (Read 2791 times)
Offline atavar
Sticky switch
« on: June 16, 2015, 04:17:18 PM »
As we all know the switchworks is a if not the weak link in Guzzidom.  I know it is a minor thing, but the hi-Beam switch on my 2008 Norge is sticky.  If I try to blip the passing beam the switch locks in just like it has two Hi-Beam positions and I have to manually pull it back.
I am thinking of opening up the switch housing to investigate and clean.  Is this a good idea or would I be stepping in to a tar pit I could never get out of?
Offline Idontwantapickle
Re: Sticky switch
« Reply #1 on: June 16, 2015, 06:48:26 PM »
Maybe a tiny squirt of silicon spray or white lithium grease would free it up without taking it apart.
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline organfixsing
Re: Sticky switch
« Reply #2 on: June 16, 2015, 06:55:28 PM »
I would try a Teflon spray into the switch lever. It is harmess to plastics, and non sticky.
Cheers
Brian  :cheesy:
If you remove the wings of a fly, does that make it a walk?
Offline atavar
Re: Sticky switch
« Reply #3 on: June 16, 2015, 07:29:17 PM »
Yeah, my concern is that Guzzi switches are not sealed units, and squirting oil on electrical contacts can summon all manner of demons.
Re: Sticky switch
« Reply #4 on: June 17, 2015, 10:20:10 AM »
The grease goes hard after a few years, I would wipe it out and replace it with fresh petroleum jelly aka Vaseline.
You could try one of the sprays, I'm just old fashion I guess.
Offline Jurgen
Re: Sticky switch
« Reply #5 on: June 17, 2015, 05:59:08 PM »
As an old time watch and clock repairer (not maker), I've always believed that disassembly and cleaning works wonders.  Old grease solidifies, oil dries out and becomes sticky and just squirting something into an assembly is a crap-shoot, you can't tell where it all goes, or not goes.  (but it is worth a try, just be aware that a disassembly might be a day or two away after all).  Unless something is worn out, a good cleaning and proper greasing (not too much) ad you'll have a new switch.
Jurgen
