Author Topic: Need ideas for a battery hold down  (Read 9590 times)
Offline Farmer Dan
« on: June 22, 2015, 04:10:10 PM »
Put a new battery in the Eldorado today.  This battery is smaller in physical size than the original battery so I need to make a hold down bracket or frame.  Like to see what others have made for their batteries.  This is a Motobatt MBTX16U.
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
Re: Need ideas for a battery hold down
« Reply #1 on: June 22, 2015, 04:47:35 PM »
This an Odyssey in my Eldo and a NAPA battery clamp (two steel rods and a plastic clamp
Used a small section of aluminum angle as a battery bracket
I also fitted a modern fuse box beside the battery and a battery disconnect switch with the flip lever to the switch accessible from outside the side cover
I run an alternator so the reg/rec is not required and more space is freed up
« Reply #2 on: June 22, 2015, 04:52:58 PM »
I use a small truck tarp strap on my 700. CHEAP
« Reply #3 on: June 22, 2015, 05:08:37 PM »
A piece of 1" wide, 1/8" thick steel strap, 9 in. long., 8" center-to-center on the holes IIRC. "J" bolts from Advance Auto. Holes were already drilled in the battery tray.
You can also do the same thing except utilizing the original holddown bolt holes, if you make a longer strap and run it diagonally across the top of the battery.
« Last Edit: June 22, 2015, 05:11:15 PM by Antietam Classic Cycle »
Offline Rich A
« Reply #4 on: June 22, 2015, 06:07:56 PM »
I made this for one of my loops:
I made another frame similar to this but it holds the battery so that it is more vertical (and the strap goes front-to-back rather than side-to-side.
Rich A
« Reply #5 on: June 22, 2015, 06:25:56 PM »
I don't even have a loopframe but curious what your set up is? alternator in place of the generator or on the crank like Tonti bikes?
« Reply #6 on: June 22, 2015, 06:39:14 PM »
It's an alternator conversion kit from Scrambler Cycle, plug and play installation. A very easy conversion and a complete kit with bracket, alternator and wore harness.
Cheers
Jim
« Reply #7 on: June 22, 2015, 07:10:12 PM »
Ah I see, had not heard of them but it must be nice to ditch that big ol generator and the mount that tends to bust.
« Reply #8 on: June 22, 2015, 07:59:59 PM »
The bracket isn't really that much smaller:
Kevin supplies one "brace", but I still add an arm back to the distributor bolt for more support.
Offline Perazzimx14
« Reply #9 on: June 23, 2015, 05:26:37 PM »
I use a giant zip tie typically used for securing flex duct to collars. Lowes has them in 30" x 3/8" wide.  Carry a spare rolled up on top of the battery secured with the 1st zip tie.
2017 Road Glide Special
2020 Kawasaki KLX300SM
« Reply #10 on: June 23, 2015, 05:38:09 PM »
Two identical aluminium straps that hook onto the edge of the platform bent to meet in the middle of the battery fastened with a 6mm bolt, no hole drilling required.
Offline lorazepam
  • Almost ready for suspenders
« Reply #11 on: June 23, 2015, 05:40:54 PM »
Plumber's tape.
Offline Farmer Dan
« Reply #12 on: June 23, 2015, 05:51:55 PM »
Got it figured out.  $8 from the auto parts store.  Be nice if there was a motorcycle shop in this part of the state.  Sure starts better with the correct battery in there.  :thumb:
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
father guzzi obrian
« Reply #13 on: June 23, 2015, 07:55:33 PM »
For years, I used a $20 lawn tractor battery and a bungee cord on my Eldo, worked dandy (guzzi content)
Offline eldoroddo
« Reply #14 on: June 23, 2015, 10:54:26 PM »
Sears sells an adjustable hard plastic battery hold down for around $10.
You won't need anything else or have to fabricate some goofy hillbilly alternative.
« Reply #15 on: June 24, 2015, 12:51:41 AM »
Sorry to hijack the thread,
What is the proper place for the regulator?
Offline Farmer Dan
« Reply #16 on: June 24, 2015, 06:50:16 AM »
The one in my picture is in the proper place.
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
« Reply #17 on: June 24, 2015, 08:33:43 AM »
 :rolleyes:  I wouldn't call any of the examples posted a "goofy hillbilly alternative".
« Last Edit: June 24, 2015, 08:38:32 AM by Antietam Classic Cycle »
Offline tris
« Reply #18 on: June 25, 2015, 06:26:31 AM »
Useful for getting them out too if the battery sits in a bit of a hole as it does on my Cali  and you can't get you fingers under it to lift it out :thumb:
1993 TW125 "POS" - Resting
