Author Topic: Drilling holes in alternator covers  (Read 3213 times)
Offline NCAmother
« on: June 23, 2015, 12:20:03 PM »
I've seen few guzzles online with "breathing patterns" cut into the alternator cutter.   Seems like it would be a disadvantage in the real world (water/mud).  Is this just an aesthitic decision these guys made?
Howdy
Offline NCAmother
Re: Drilling holes in alternator covers
« Reply #1 on: June 23, 2015, 12:36:33 PM »
Probably a styling exercise Nate , although air head beemers used vented covers , probably to keep the diode board cool .
That's interesting Dusty, I would just assume disaster after a few thousand miles riding in dirt and rain.
Nate
Howdy
« Reply #2 on: June 23, 2015, 12:42:34 PM »
What bike are you talking about?
Most of the late model Tonti alternator covers are spaced away from the motor to allow air flow between them and the motor.
I understand the the latest V7 models run the alternator in an oil bath.
« Last Edit: June 23, 2015, 01:38:29 PM by Wayne Orwig »
Offline Testarossa
    • Skiing History
« Reply #3 on: June 23, 2015, 12:50:09 PM »
From the T3 onward, Tonti alternators produced enough heat to melt the insulation on the wiring connectors (happened to my T with an upgraded stator). Those bikes need airflow. You can fit a plastic aftermarket spacer, fiddle up a homemade spacer system or drill the cover.
See http://www.mgcycle.com/index.php?main_page=product_info&cPath=37_161&products_id=784
Offline PeteS
« Reply #4 on: June 23, 2015, 12:56:13 PM »
My '76 came without a spacer. I later added the one sold by MGcycle. It must work as I still have the original parts in there and water and debris don't seem to be an issue.
Offline guzzimatic
« Reply #5 on: June 23, 2015, 03:04:42 PM »
no need to drill,I use SS washers to space the cover about a 1/16 in.allows heat to escape,gives water a way to drain.I have learned setting up shocking boats for Biologists that any cover needs at least an 1/8 in.hole to let water out...
big Jim Walker bikes:'08 Norge,02'DR650,'84LeMans III,,'78 honda cb750k,'78 BMW R100S,'77 Ducati 860GT ES,'77honda XR75, '76 GUZZI convert,'75 850T cafe[project],'75 RD350 yamaha,'74 NORTON commando,'72 750 Norton flattrack replica,'72 250 Rickman-Montesa,'72 XL250 Honda Mosport[first bike
