What bulb No. is that?
OK Muzz old man , but are they the plastic socket holders ? So far all of the advice has been to not ride at night , nothing on how to fix the tail light Dusty
Looks like 1577. Pre ride check its working fine. I almkat wish it was a full screw in. Instead of this half twist socket.
Don't listen to the scairdey cats. nd stay inside them where you can ride safe, but ride!
Clean, bend, dielectric lube to prevent repeat.
dielectric grease is electrically insulating
It can be applied to the actual contact as well, because the contact pressure is sufficient to penetrate the grease. Doing so on such high pressure contact surfaces between different metals has the advantage of sealing the contact area against electrolytes that might cause rapid galvanic corrosion.
Only had her two weeks and she's already so needy!!!
I heard that dielectric grease is really an insulator, not a conductor and maybe not the best thing to use here.But you can't believe everything you hear, so I looked on wikipedia (infallible) and it confirms,... but also,Unfortunately the entry for petroleum jelly doesn't address its electrical properties, but from some other commentary I found online, I gather that as one might expect, it's also an insulator, and as far as I know they're equal on that score. The impression I get is that dielectric grease might be a superior alternative, if only because of a higher melting temperature.
I have been using Petroleum Jelly aka Vaseline on electrical contacts and around batteries for over 50 years, I'm not about to change.
Kiwi,I hate to break it to you but Vaseline *is* a dielectric grease. Dielectric grease is simply a lubricating non-evaporating non-conducting moisture blocking compound with a relatively low surface tension. That pretty well describes Vaseline. While most dielectric greases are silicone based (better for high voltage applications and non-flammable) they can also be petroleum based.
I have been waiting for someone with a Breva to step in and offer the solution, I can only guess what the lamp holder is like.The lamp should be spring loaded by the contacts, pushing it into the socket it should take a few ounces of pressure it shouldn't feel loose at all.One of the two contacts is the tail light, the other is the stop light, the base of the lamp with the bayonet fitting is the return to negativeYou might be able to lift the reflector out, there will be two wires out the back (Tail and Stop) and another to the reflector or the reflector makes contact with the chassis somehow. You should be able to wobble the lamp around without it going out.It could also be a faulty bulb, the filaments sometimes break and touch.Do you know anyone else with a bike, any brand who can help you learn about electrics, it's really very easy.Any other Guzzi owners in Kansas City, I'm sure they will be glad to help you with this.Buy yourself a small multimeter ~$10 and learn how to measure for Voltage, Ohms etc Electricity is fun.There's been some discussion about di-electric grease, I have no experience with the stuff but if people like Chuck and Wayne say it's no good that's good enough for me. No grease conducts electricity, it stops corrosion and lubricates. I have been using Petroleum Jelly aka Vaseline on electrical contacts and around batteries for over 50 years, I'm not about to change.
I'd bet on a couple more things breaking in the near future, but hopefully just minor things. Hope it didn't sit around for really long intervals with gas in it, in its previous circumstances.
shes still running very well and that makes me happy.
My mechanic has a 70s (i think) California, he came over yesterday and put on new tires, took a look at the taillight and betting when the guy put a new light in he pushed too hard in to turn it, as all my mechanic had to do was reach in and pull the back connector out (was pushed in too flag). YAY so excited.
