Author Topic: cali EV mods , too lean ? advice ....please  (Read 2608 times)
Offline arveno
    • ddleathers.com
« on: June 28, 2015, 05:40:51 PM »
Hi All
I almost finish my 98 cali ev.
Put k&n air pod ( trashed the whole air box ) stucchi cross over and lafranc competizione .
I was wondering if anyone ever done similar mods ? I am a bit worried that the engine may be a little too lean ?
If so , how do i correct that ?
Bike got stock computer . P8
any help highly appreciated.
Marco
Ah forgot to ask : i trashed all the canisters etc.... i see the intake manifolds have a breathing hose , what should i do with those ?
tie the end of the hose somewhere , or close take out the hose and close the hole ?
Online LowRyter
Re: cali EV mods , too lean ? advice ....please
« Reply #1 on: June 28, 2015, 06:50:55 PM »
the computer has a mixture adjustment screw on it.
does the bike backfire or do the plugs burned?
Offline Hahnda
    • Scrambler Cycle
« Reply #2 on: June 28, 2015, 07:57:31 PM »
The manual says that adjustment screw only has an effect up to 2000 rpm but I feel that it changes it through a much wider range. If you make an adjustment and go for a ride you can tell that an adjustment has been made at RPM's higher than idle speeds.
1949 GTV - 1948 Airone
www.scramblercycle. com
Offline arveno
    • ddleathers.com
« Reply #3 on: June 28, 2015, 08:08:50 PM »
it back fires a little.... i am going to play a little with the CO adjustment screw, thanks for the info...
How about the below question ?
thanks again
« Last Edit: June 28, 2015, 08:10:50 PM by arveno »
Offline Hahnda
    • Scrambler Cycle
« Reply #4 on: June 28, 2015, 08:17:52 PM »
You could connect one to the other or cap them off.
Offline arveno
    • ddleathers.com
« Reply #5 on: June 28, 2015, 08:25:44 PM »
ok , got it !
thanks
