Author Topic: Handlebar Clamps (G5, T3. Convert, Etc)  (Read 4047 times)
Offline Groover
    • Scooteropolis
« on: June 29, 2015, 04:35:57 PM »
Are there upgrades to the factory clamps that came on the G5. Convert, T3's etc. Something a little beefier?
This is the part (x2)
Thanks!
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Re: Handlebar Clamps (G5, T3. Convert, Etc)
« Reply #1 on: June 29, 2015, 04:50:09 PM »
why beefier? never heard of them failing.
Offline Groover
    • Scooteropolis
« Reply #2 on: June 30, 2015, 10:09:59 AM »
Just wondering if something like this would fit. It's from the Mille GT:
http://www.harpermoto.com/plate-28500233.html
1980 Vespa SI Moped
Offline twhitaker
« Reply #3 on: June 30, 2015, 10:31:23 AM »
That part has a couple holes in the front for attaching the dash.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline Groover
    • Scooteropolis
« Reply #4 on: June 30, 2015, 12:25:17 PM »
I didn't know that, but I can see that now looking at some Mille photos. Do you happen to know of the bolt pattern matches? I may not replace mine, I'm just wondering at this point. It would make me feel a little better having a solid clamp verses the two smaller ones I think.
1980 Vespa SI Moped
« Reply #5 on: June 30, 2015, 12:31:59 PM »
Even with the plate you still have two lower clamp halves on the tree.  There is no structural advantage to the plate concept on the old tonti clamps.
Is there something wrong with the ones you have or are you just looking for something to do?
Offline twhitaker
« Reply #6 on: June 30, 2015, 12:35:03 PM »
Should not be of an advantage at all. Looking at the underside of that clamp, other than the two bosses the material is about 1/8" thick. I can measure the spacing on my Cali. If I remember to.
MGNOC-11168
Dayton, OH
Offline Groover
    • Scooteropolis
« Reply #7 on: July 01, 2015, 08:22:08 AM »
Ok, thanks guys. I'll just be leaving mine as-is. I was just wondering what was available if anything. I just had these in my hands recently when I painted them and they just seemed light in my hands so started thinking.
Thanks again.
1980 Vespa SI Moped
« Reply #8 on: July 01, 2015, 11:14:07 AM »
If those clamps worry you do NOT look what is under the triple tree :D  They are relatively thin castings.
But,they also go many, many miles without incident.  I just put 2 1/2" risers on mine.  Just make sure you don't torque the bolts too tight :D
