Author Topic: 07 Norge red Triangle of Death illuminated  (Read 4385 times)
Offline Stormtruck2
  • AKA Scotch and Cigars
  • Geese Fly in a Proper V
« on: July 01, 2015, 07:27:39 PM »
I changed the oil pressure sensor and cleaned the engine up real well.  Crusty helped me put her all back together yesterday and I took her out for a shake down run.  One mile into the run the red triangle of death came on.  The sensor is brand new, I hope it's not bad. Oil level is good, just below half. I'm open to suggestions of what and where to check.
μολὼν λαβέ-molṑn labé
Online Wayne Orwig
Re: 07 Norge red Triangle of Death illuminated
« Reply #1 on: July 01, 2015, 07:45:57 PM »
Why did you change the sensor in the first place?
Offline Stormtruck2
« Reply #2 on: July 01, 2015, 07:54:19 PM »
Was having persistent oil misting problem.  30,000 miles and it kept oiling the left side lower.  Replaced the hose, and used RTV to try and seal it.  After looking closely at the sending unit it looked like oil may have been wicking up through the wires.
Offline Moz
« Reply #3 on: July 01, 2015, 08:03:10 PM »
my bellagio of that era often starts with that red light..  oil level is fine.  there is some misting oil out of the left head, but not enough to bother me - it's a daily ride and never particularly clean   :rolleyes:
Anyway, when it does it, I turn ignition switch off and on and it's gone.. sometimes.. it will usually be off if I actually start the bike before the needle settles back down after turning ignition on..
Good moto guzzi mechanic here in Sydney (John at Motociclo) said there's some problem there but worth trying to isolate when it's no real problem..  :angel:
'82 le mans iii
'08 cafe's bellagio
'20 V85TT
Offline bad Chad
« Reply #4 on: July 01, 2015, 08:17:23 PM »
The red triangle of death, is not really so bad.  It means there is a problem some where with something.  Mine comes on occasionally, but there is actually nothing of any measure wrong with the bike.  It started after I put an after market exhaust on.  I studied it a while, and have determined it's no big deal.
Like Moz said, it usually goes away if I shut it down, and restart.
1988 YX600 Radian
Offline Stormtruck2
« Reply #5 on: July 01, 2015, 08:24:26 PM »
I did shut down, then restarted it, then less than a mile it came back on.  Engine sound did not change.  Light came on and I shut the engine down.  Checked things over, restarted it, no light.  Took off to return to the house and it came back on.  Pulled into the house and wrote you guys..  What now Chief??
« Reply #6 on: July 01, 2015, 10:00:03 PM »
Do you have the old sensor? Would it be that you could put the old sensor back in and if there is no light then the new sensor could be kaput.
Offline sbaker
  • Piaggio Stock Holder
« Reply #7 on: July 01, 2015, 10:07:36 PM »
What oil are you using??
Sam
Dallas, TX
AGATT
Current
Norge Wing: White Squadron
Ducati 900ss
Previous
1975 Convert + Sidecar - Fun
2004 California EV Touring
Offline Stormtruck2
« Reply #8 on: July 01, 2015, 10:24:12 PM »
10W60 AGIP T4
Offline twodogs
« Reply #9 on: July 02, 2015, 05:52:25 AM »
Hey Storm, they told me the pressure switch had a bad batch come in and if the black plastic top moved around a little it was bad so I replaced mine and the problem went away, I replaced the factory connector to the switch also, so far 3000 miles and no problem, look at the sensor next to the pressure switch, it seems to leak a lot, little o-ring replaced. all good.
1983 Honda CB1100F
2024Triumph 400 Speed x2
