Author Topic: Oil filter in Breva 750  (Read 5193 times)
Offline Jurgen
« on: July 03, 2015, 06:37:44 PM »
Can anyone tell me where the oil filter on a Breva 750 is located?  Do I have to drop the oil pan to access the filter?  I'm new to the Breva and have changed oil, but could not find the filter.  Thanks for any info.  Jürgen
Jurgen
Offline cloudbase
Re: Oil filter in Breva 750
« Reply #1 on: July 03, 2015, 06:42:12 PM »
There is a small circular plate that has to be removed from the bottom of the oil pan that will give you access to the filter.
Offline jackson
« Reply #2 on: July 03, 2015, 06:57:01 PM »
And there are two drain bolts on the pan; one on the very front of the pan and the other is on the rear.
NO longer can ride
Offline malik
« Reply #3 on: July 03, 2015, 07:08:26 PM »
Accessible from underneath at the front
http://www.stein-dinse.biz/eliste/bilder/303031393034.gif
Offline M0T0Geezer
    • The Ones I Rode
« Reply #4 on: July 03, 2015, 09:12:21 PM »
Ditto that.
Remember the filter goes in with the attached spring pointing down.
Beware of over-torquing the long center bolt that holds the circular plate and filter in place.
I have a torque wrench but in this case I think that "snug" by a hand wrench is adequate on that easy to strip bolt.  We're not tightening lug nuts on the school bus here.
If the circular plate weeps a little oil film after riding a while then you can tweak the center bolt a bit more but go easy.
Remember that both oil plugs and the oil filter bolt have crush washers that need to be replaced - at least every other oil change.  There are also o-rings associated with the oil filter, the circular plate, and the dipstick.  These are not included with the oil filter and have to be requested separately.
'Geezer
Wisdom from the road:
Offline Jurgen
« Reply #5 on: July 03, 2015, 10:07:18 PM »
Thanks everyone!  I'll do the oil change correctly next time w/filter.  Jürgen
Jurgen
