Author Topic: Crimp or solder electrical connections  (Read 25416 times)
Re: Crimp or solder electrical connections
« Reply #60 on: July 07, 2015, 05:30:47 PM »
A good source of auto-grade wires is junk cars.  I strip harnesses at no cost to the owner ( :grin: ) and then have a good variety of colors, hashes, and gauges for almost any task.
I prefer to use marine grade when I can afford it.  The local marine supply has primary wire (solid color) in most common sizes.  It's a multi-stranded, double-insulated wire with each individual strand tinned.
When I think about it, all of my diy projects trend toward marine grade connectors, shrink, wire, switches. etc.  Unlike automotive and m/c, marine stuff assumes it's gonna get wet with all sorts of liquids for all kinds of time.
 . . .and sorry for the misinformation re: electrons and the surface of a conductor.  I had been taught that in what amounted to a HF instrument class and assumed it was a universal truth.    :embarrassed:
« Reply #61 on: July 07, 2015, 06:08:46 PM »
 :1:
Stopped buying auto wire and connectors some time ago unless I am desperate. Marine grade is the way to go. It holds up better, works better and is just better.
Offline Dimples
« Reply #62 on: July 07, 2015, 07:12:48 PM »
After reading all of this it's my opinion as retired licensed master electrician and contractor that some of you are getting carried away with details. It's like a convention of gov't workers "how can we design complication into a simple job?"I used the tool above to stake on thousands of termination is all sorts of conditions,some quite nasty and nothing failed. I've made up many wire harness for vibration prone motorcycles and none fell apart....Buy the tool, use De Ox grease , shrink tubing to help support the wire, get good quality terminals and leave a bit of slack in the wire. It's all in your hands....
I think you are referring to this conductive grease product NO-OX-ID:
http://www.sanchem.com/electrical-contact-lubricant.html
'96 Sport 1100
'71 Ambassador
'81 V50 Monza
'83 850 Le Mans III
'85 Le Mans 1000
'04 V11 Le Mans Nero Corsa
'77 850 T3
« Reply #63 on: July 08, 2015, 05:51:12 AM »
It reads like a snake oil add
« Reply #64 on: July 08, 2015, 07:55:34 AM »
I've used Penetrox in special applications that required it.
http://ecat.burndy.com/Comergent/burndy/cat/602945
