Author Topic: help uploading map wi Guzzidiag  (Read 3608 times)
Offline boatdetective
« on: July 11, 2015, 01:39:37 PM »
Hello-  So I have IAW 15 writer v. 2.6 open-
- I click to browse for my new map
-my file directory pops up
-I click on the file folder with my Guzzidiag stuff and other maps
...and no files pop up when I click on the folder.  Nada- zip. I have at least three .bin files in there
Any guesses?
BTW- I only have COM3 popping up as a selection for input ports.
Jonathan K
Marblehead, MA
1981 V50III "Gina"
2007 1200 Sport "Ginger"
beetle
Re: help uploading map wi Guzzidiag
« Reply #1 on: July 11, 2015, 03:44:06 PM »
You need the IAW5xWriter. 07 Sport has a 5AM ECU.  :thumb:
15x writer won't see 5AM maps. They are a different size.
« Reply #2 on: July 11, 2015, 09:20:53 PM »
thanks Beetle- I kindov figured it out on my own with the other writer. I loaded the map you sent me. BTW, the file you sent is "Sport FU2-4V-E3F2.2015.01.15.bin".  My bike is a 2V- is your map for the 4V Breva Sport?
I reset the TPS. It will only reset to  4.8. I reset the auto learning function. I alo removed tte "O2 Opimizer" he bike now has a problem dying at itle (sometimes) and pops on the decel.
Any ideas?
Jonathan K
Marblehead, MA
1981 V50III "Gina"
beetle
« Reply #3 on: July 11, 2015, 09:44:55 PM »
No, that's a 2V map.  4.8 TPS is fine.  Try adjusting CO trim to +3 or +5.
« Reply #4 on: July 11, 2015, 11:05:08 PM »
Also have you re-set the self learning parameters? If not, do so.
« Reply #5 on: July 12, 2015, 08:40:08 AM »
Yes sir. Thanks.
It has taken me a bit, but on the whole I'm a believer that the pretty basic injection system on these bikes is worlds easier to deal with than carbs (I know- heresy to the suspenders crowd)
Jonathan K
Marblehead, MA
1981 V50III "Gina"
« Reply #6 on: July 12, 2015, 08:46:31 AM »
I always use the reader first to read the current map and set aside the original bin file. It is a good idea in case you need to restore it. That also give you a good feeling that the communications is solid, before doing the write.
