Author Topic: Oil pressure sensor change solution!  (Read 56141 times)
Offline ITSec
Re: Oil pressure sensor change solution!
« Reply #30 on: July 23, 2016, 07:15:08 PM »
Yep, you could actually lengthen the hose and mount it next to the instruments so you could monitor it as you rode. Then you could also run a separate ground wire to the block just to be sure it had the proper grounding.
Maybe you could have a small lipstick camera focused on it as well so you can see if it leaks or anything while the bike is parked and your at work or whatever.
Seem doable.
Ciao
Spoken with the tone of someone who's never had to put a wrench in where this thing is mounted!  :grin:
Or you already have an offset crowfoot extension in your toolbox?
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline skimbrie
« Reply #31 on: January 04, 2017, 03:53:37 PM »
I used this solution along with ITSEC's wiring kit and thought y'all might like to see a picture of the result. Neat, sweet, and complete.
-Scott K.
'20 v85tt
« Reply #32 on: January 04, 2017, 06:58:36 PM »
Is that a new model switch or does it have a 1" long adapter between engine case and switch.
Part No ?
Never mind I see the link to the NAPA part, it cant be any worse than the Guzzi one for sure.
Am I right in thinking it has a thread adapter to 12mm from what?
BTW welcome to the forum
Roy
« Last Edit: January 04, 2017, 07:08:55 PM by Kiwi_Roy »
Offline skimbrie
« Reply #33 on: January 04, 2017, 08:44:30 PM »
Part No ?
Roy
It's a new model switch (641541) with an adapter (887123) from Harper's MG. I didn't check the dimensions - just screwed it together.
-Scott K.
'20 v85tt
Offline old head
« Reply #34 on: January 05, 2017, 04:01:01 PM »
this is what I replaced by weaping sensor with, about 6 months ago.  Working fine so far.  far easier than fussing with adaptors and extra wiring.
Duralast looks to the same connector
Part Number: PS486
Alternate Part Number: OP25891
http://www.thisoldtractor.com/moto_guzzi_loopframe_oil_pressure_sending_unit_cross_references.html
06 Breva 1100
Hepco-Becker crash bars
Givi A620 screen
Garmin GPS
Offline mojohand
« Reply #35 on: March 21, 2018, 11:04:29 AM »
My brother Ray's 2008 Norge has been throwing the red triangle and, occasionally, the oil can. Looking into replacing with one of these solutions.
Richmond, VA, USA
2020 BMW R1250RS
Previous: 2000 Jackal, 04 Breva 750, 06 Breva 1100, 07 Norge, 09 Griso, 12 Norge, 14 FJR, 14 Striple, 16 SpeedTriple, 18 KTM Super Adventure S
Offline mojohand
« Reply #36 on: March 21, 2018, 11:32:41 AM »
ITSec--any chance you have some kits layin' around?
Richmond, VA, USA
2020 BMW R1250RS
Offline ITSec
« Reply #37 on: March 21, 2018, 11:46:34 AM »
I'll take a look - I think I'm out of the ones with the older nail-head connector. Send me a PM and let me know what type of connector your new sensor has.
ITSecurity
Offline Bulldog9
« Reply #38 on: May 01, 2021, 07:08:57 PM »
I just pulled the tank and air box today on my 1200 Sport and I'm having a heck of a time getting to the oil pressure sensor. Seems I did this on my griso with no problems but position of the sensor on the sport seems to be more inhibited by the alternator. Any tips techniques or procedures to help?
MGNOC#23231
Offline twodogs
« Reply #39 on: May 02, 2021, 08:21:44 AM »
I had to pull the left header pipe to get to it from the front and the airbox to access it from the top, it was a long and slow process, a little twist then reposition, It took awhile and I think I had to have the wife hook it back up because of smaller hands  :boozing:
1983 Honda CB1100F
2024Triumph 400 Speed x2
« Reply #40 on: May 02, 2021, 08:40:01 AM »
On my Norge, I pull the airbox and do the inner plugs while there.
Take the black cover off the front of the engine, loosen the belt adjustment and remove the alternator pivot bolt on the left (gear) side. This will allow you to easily get to the switch.
Also you can re tension the alternator belt.
It’s a good time to secure the terminal on the neutral indicator switch at the back of the gearbox as well, while you have the airbox off.
Offline lucky phil
« Reply #41 on: May 02, 2021, 04:20:25 PM »
This is the tool I made up to do the Daytona switch which is in the same location but more difficult to get to. I have an image after welding and machining somewhere.  The switch is too long for a std 1/2'' drive socket and the location is to difficult for a 22mm deep socket and extension so I cut an old 1/2" drive socket drive off and machined and welded it to a std 22mm 1/2" drive socket. I can now remove the switch with an extension with a universal fitted without pulling the tank or anything else. It works even better on a Std 2 valve engine as they are easy to access compared to the Daytona engine.
Ciao
Offline Bulldog9
« Reply #42 on: May 02, 2021, 07:23:37 PM »
I'll give it a shot, but will probably end up removing the alternator.
MGNOC#23231
« Reply #43 on: May 03, 2021, 01:35:37 AM »
Outlined in reply # 40
Offline Bulldog9
« Reply #44 on: May 03, 2021, 05:58:10 AM »
Thanks Huzo, just removing the nut/bolt gives enough room? I was thinking about just sliding the alternator back. I did this on the Griso (1100) , but it was 4 years ago, was a pain, but not this bad. Thanks for the heads up on the neutral indicator.
MGNOC#23231
« Reply #45 on: May 03, 2021, 07:20:39 AM »
Yeah mate.
Undo and remove the pinch bolt on the right (brake) side and remove the pivot bolt on the left (gear) side..
You can damn near wave the thing around your head if you do that. The switch is sitting there like a pumpkin on your kitchen table....Simples...!
Offline John Warner
  • Growing old is mandatory, growing up is not . . .
    • Stelvio/V85 Owners Group FB
Oil pressure Switch change solution!
« Reply #46 on: May 03, 2021, 08:22:16 AM »
For those with the later models, using the Bosch EV-1 Connector (Same as the Injector Connectors), you can get a replacement Switch (it is a Simple Switch, not a Sensor) from any car spares place.
The switch will screw straight into the Crankcase, and the original Plug will connect straight to it, no need for any adaptors or swapping Terminals, like Guzzi dealers will have you doing!
Doc out . . .
Stelvio Owners Group on FB ~ https://www.facebook.com/groups/888995181188209/?fref=nf
Offline lucky phil
« Reply #47 on: May 03, 2021, 03:31:02 PM »
Someone's an old aircraft mechanic. What are the switch trigger points on that newer style switch?
Ciao
Offline Bulldog9
« Reply #48 on: May 04, 2021, 10:53:14 AM »
Yeah mate.
Thanks Huzo, I disconnected the battery and terminal leads off the Alternator last night, will tackle the Alternator and switch today, and likely do a cleanup of the area while all is apart. Once the alternator is moved over, looks like it will be easy to remove.    The belt is in good shape, but will likely change it so I don't have to mess with it all in the future.
MGNOC#23231
Offline Bulldog9
« Reply #49 on: May 04, 2021, 01:26:05 PM »
Done, removing the Alternator was Easy and much better than futzing around it.
1 - Remove Tank, airbox & breather assembly
2 - Disconnect Battery and remove wires
3 - Remove Black alt belt cover
4 - Remove Bolts off right (brake side) Coilpack for easy access to alt slide bolt & remove
5 - Remove alt pivot nut (clutch side) and slide bolt out, remove alt belt.
6 - Slide Alternator back & remove
7 - You now have easy access to the oil pressure switch. Remove with 21mm box wrench (or 13/16)
8 - Clean everything up & R&R
Total time not counting tank removal was 45 minutes, and gives opportunity to change alternator belt, check connections to alternator, and is relatively easy. I spent less time doing this than I did futzing around trying to get at the bolt.
I sourced my OPS from MG Cycles, and it was a direct plug & play, no issues. I was also able to slide the rubber cap over the connector with needle nose pliers, and there is no touching the alternator nut, as the socket slid on to do a final tightening.
Removing the right coil pack made access to the adjuster easy.
New Switch compared to old
Alternator out and back in with everything connected.
Hooked up the air temp sensor in the air box and turned on the key, No more triangle of death.
Next up is hard wiring my Tom Tom Power Lead to the Stock GPS power. I have it terminated in a Tender plug and plug in a dual port USB power plug with volt meter, and it also powers my aux led lights. Wanted to do more, but ran out of time, did this during lunch. Back to work....
Thanks for the input Huzo! I would still be fighting for hours if I had not done it this way.
MGNOC#23231
« Reply #50 on: May 04, 2021, 02:46:00 PM »
No worries.
I tend to do the inner plugs when the airbox is off, if they are close to needing changing.
Some rubber grease is handy on the connectors that fit onto the TB’s as well and I find it handy to re fit the black air intakes without the clamps.. (fitting them after the box is back on).
Well done..!
Offline John Warner
« Reply #51 on: May 05, 2021, 01:23:18 PM »
Yep! Did 42 yrs as an Aircraft Engineer with BA, took Voluntary Redundancy last Aug.
LENGTH : 41.25 mm
SPANNER SIZE: 24
OUTER THREAD : M12 x 1,5 mm
NUMBER OF CONNECTORS / PORTS: 1
FUNCTION: Oil Pressure Switch
SWITCH POINT TO: 0.5 bar
SWITCH POINT FROM: 0.2 bar
COLOUR CODING: Black
THREAD LENGTH : 12 mm
It's been on my 2009 Stelvio now for a couple of years, no issues.
Doc out . . .
Offline lucky phil
« Reply #52 on: May 05, 2021, 03:38:50 PM »
LENGTH : 41.25 mm
SPANNER SIZE: 24
Thanks for the info. Same here, 42 years with QF and VR five years ago. You can always tell as most non aviation people can't lockwire.
Ciao
« Last Edit: May 06, 2021, 03:40:32 PM by lucky phil »
Offline John Warner
« Reply #53 on: May 06, 2021, 02:14:10 PM »
Just found this, knew I'd seen the Switch type listed somewhere . . .
So it's a 'Normally Closed' (NC) Switch, circuit 'opens' when the Oil reaches the pre-set pressure.
Doc out . . .
Offline SemperVee
  • USMC Retired
« Reply #54 on: September 24, 2024, 01:59:00 PM »
 Update not to start new thread.    Oil pressure sensor/switch went out.  Replacement can be had from NAPA with a M12 1.5 spade type connector for my
07 Norge and apparently many others.  Echlin OP6065 model.  See list included that needs to be updated as most are NIS and out of date.
« Last Edit: September 24, 2024, 02:01:30 PM by SemperVee »
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
« Reply #55 on: October 21, 2024, 05:19:48 PM »
The problem with these stupid little sensors.
The movement is so tiny and stiff its very hard to get enough motion to operate a decent switch.
Kiwi Roy
Instrumentation Tech for 50+ years.
« Reply #56 on: October 21, 2024, 05:28:38 PM »
Kiwi Roy
Is that the problem with these things KR ?
« Reply #57 on: October 21, 2024, 07:00:05 PM »
We need a switch with much more stroke in the sensing unit so it can operate a microswitch not that simple contact
Something like the switch on an air compressor that you can adjust.
A while back I looked at using a pressure transducer with a linear output in conjunction with a comparator driven relay or solid state output but it got shelved as too complicated (costly)
You can buy sensors 0 - 100 psi with 0 - 10 Volt output
I have run gauges on some of my Guzzi's, 0 - 100 psi is a good range, the bikes I am familiar with operate ~60 psi.
A switch point of 40 psi would be good.
« Last Edit: October 21, 2024, 07:18:18 PM by Kiwi_Roy »
