Author Topic: alt. belt tension on Norge  (Read 2174 times)
Offline guzzimatic
« on: July 22, 2015, 10:39:53 AM »
A bit of help please...I am going to change my alt. belt on the Norge at about 42000 miles.what is the trick for setting the tension without the factory tool? I seem to remember Vasco saying the tension tool was not needed but only slightly remember how to test,can't twist the belt to 90 degrees? Thanks all...OK first time I have had search work ! I found several threads,so Bob's your Uncle...
« Last Edit: July 22, 2015, 04:21:38 PM by guzzimatic »
big Jim Walker bikes:'08 Norge,02'DR650,'84LeMans III,,'78 honda cb750k,'78 BMW R100S,'77 Ducati 860GT ES,'77honda XR75, '76 GUZZI convert,'75 850T cafe[project],'75 RD350 yamaha,'74 NORTON commando,'72 750 Norton flattrack replica,'72 250 Rickman-Montesa,'72 XL250 Honda Mosport[first bike
Re: alt. belt tension on Norge
« Reply #1 on: July 22, 2015, 04:21:37 PM »
That's basically it. Hold the belt in the middle of its run and twist it. See if you can find someone local familiar with tensioning belts. It's not rocket science. You want it tight enough not to slip but not so tight it will damage the bearings.
