Author Topic: Anyone want to take a stab at my drilling problem?  (Read 14700 times)
Offline drums4money
Re: Anyone want to take a stab at my drilling problem?
« Reply #30 on: July 24, 2015, 05:14:07 PM »
I'd never trust something like that in an airplane, even if it *is* an ultralight or something. A proper cotter pin won't vibrate loose.
Do it right . . .use a Welcome Back Kotter pin
Old School Audio:
Offline rboe
« Reply #31 on: July 24, 2015, 05:45:47 PM »
Used hook & loop on my Quota seat. Worked.
Thinking out loud here, I wonder if someone couldn't weld your cap to the pin (gonna call it a root canal now!  :grin: ).
I do like what you did though.  :bow:
Phoenix, AZ
2008 Honda XR650L
2012 Griso SE
2013 Honda CB1100
« Reply #32 on: July 27, 2015, 02:44:08 PM »
Well it works!
Very VERY solid connection
I used two clips, one around the bolt under the head and one thru the hole I drilled
Clean install!
« Last Edit: July 27, 2015, 02:47:49 PM by Mayor_of_BBQ »
Offline kirb
« Reply #33 on: July 27, 2015, 03:14:05 PM »
Velcro , don't laugh , a couple of loops will hold a seat in place , no drilling , get back on the road .
WAY better than velcro: http://solutions.3m.com/wps/portal/3M/en_US/Adhesives/Tapes/Brands/Dual-Lock-Reclosable-Fasteners/
Works when wet, there isn't a hook side and a loop side- both are the same, very good adhesive- can also be mounted with hardware: http://solutions.3m.com/wps/portal/3M/en_US/Adhesives/Tapes/Products/~/3M-Dual-Lock-Reclosable-Fastener-SJ3463?N=5927706+3294281449&rt=rud
Seems like this was sorted out in a much better way, but the dual lock is ideal for a lot of different uses.
« Reply #34 on: July 27, 2015, 03:45:24 PM »
Belt *and* suspenders..  :grin:
