Author Topic: Brake lights flashing? Cal 1400  (Read 4618 times)
Offline JQ
« on: July 24, 2015, 10:49:53 PM »
Can anyone tell me why my brake lights are flashing?
Only the brake lights, nothing in the front.
They flash with the engine running or off, and with the ignition on or off.
I noticed it when I pulled into my driveway, but for all I know they were flashing while I was driving.
I've looked for something in the owners manual, but nada.
Thanks.
Offline JQ
Re: Brake lights flashing? Cal 1400
« Reply #1 on: July 25, 2015, 12:59:10 AM »
When I disconnect the negative terminal of the battery, the flashing stops.  When I reconnect, the flashing resumes.
« Reply #2 on: July 25, 2015, 02:26:52 AM »
I had this issue when I first demo' done but I can't for the life of me what it was. Something related to the alarm I think? Have you read the book?
Offline segesta
« Reply #3 on: July 25, 2015, 09:14:51 AM »
This won't help, but I can confirm that there's nothing in the owner's manual about brake lights flashing based on some fault or alarm. Hmmm...
2013 Ducati Monster 796
2010 BMW K1300GT
Offline rtbickel
« Reply #4 on: July 25, 2015, 09:22:24 AM »
Try using the alarm bypass plug that came with the bike
2020 V85TT
Offline Wissing
« Reply #5 on: July 25, 2015, 09:38:05 AM »
I posted on the same issue a year ago. I thought something was wrong, then somebody read the manual for me 😉. It is a hazard flash future of the alarm. It is turned on when the button on the fob is pushed with ignition on, and it will continue to flash the brake ligths even if the key is removed. It is turned off the same way - push the fob button once with ignition on.
MG V85TT Travel
MG California 1400 Touring (sold)
Honda CTX700D
Indian Scout
Offline ibis1
« Reply #6 on: July 25, 2015, 09:59:31 AM »
Are you sure you're not removing your key in the "Parking Lights" position? That illuminates some lights to help spot the bike if it is parked near a roadway.  :boozing:
2010 California Vintage (Gone)
1971 750 Ambassador (Gone)
2014 California Touring
Offline JQ
« Reply #7 on: July 25, 2015, 12:22:46 PM »
Problem solved.  Thanks, everyone.
Jim Barons got me straightened out.
Apparently I pushed the wrong button on the Alarm Fob.
To stop the flashing I had to push that button - the large button - again, twice.  Then pull out the key.
Then I was good to go.
Glad this happened to me in my garage.
Thanks again.
