Cool Weather vs. Hot
Topic: Cool Weather vs. Hot (Read 2617 times)
JeffOlson
July 28, 2015, 10:29:21 AM »
In cold or cool weather (30s, 40s, 50, and even 60s), my Norge runs great. It is smooth. It purrs. It shifts well. It tolerates low revs. I love it!
In hot weather (80s, 90s, 100s), however, it does not run nearly as well. It groans, vibrates, bucks, and lurches. It will not tolerate low revs. It is like it is a different bike. If I did not know how well it runs in cold or cool weather, I might not put up with it. I might ride my Vespa instead.
What gives, and what can be done (other than riding my Vespa)?
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
Gliderjohn
Re: Cool Weather vs. Hot
Reply #1 on:
July 28, 2015, 10:30:57 AM »
Hmmm! Not noticed any of that on mine. Don't know.
Back in central KS
Groover
If it ain't broke, I'll break it.
Reply #2 on:
July 28, 2015, 10:46:47 AM »
Is the Norge FI or Carb intake? If carb, then you can richen the low end needle valves on the carbs maybe 1/2 to 3/4 of a turn on each (richen = unscrew them counterclockwise on Dellorto carbs). If Fuel Injected, then not sure. Maybe the map (If applicable) needs to be tuned to richen the low end a bit,
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
JeffOlson
Reply #3 on:
July 28, 2015, 10:53:21 AM »
^ FI.
It looks like I need to borrow a PC from my brother and upload Mark's latest Norge map. (I have Macs, but the GuzziDiag writer program cannot "see" any maps on my Macs, so I am not able to use it to upload a new map.)
2018 Vespa GTS 300
2015 Vespa GTS 300
Bobolink
Reply #4 on:
July 28, 2015, 11:03:21 AM »
Do you still have the evaporative canister? After removing mine, the bike seemed to smooth out a bit.
You may want to check TB sync and valves.
I'm not sure if there is a ambient temp sensor that alters fueling, but I had a hot weather cold start issue with my Norge; my issue, however, seems to have corrected itself after two years.
Bobolink
Reply #5 on:
July 28, 2015, 11:06:08 AM »
Marks map, as good as it is, may not help if something is out of tune.
Last Edit: July 28, 2015, 11:17:44 AM by Bobolink
Groover
Reply #6 on:
July 28, 2015, 11:18:49 AM »
I've messed with maps on a bike I used to have and I tried trading maps with other people around the country at different sea levels; What worked well on one bike didn't work well on another, same variables otherwise. That was a power commander III unit that would override the factory ECU. If it's that type where you can adjust fuel levels at different throttle levels, then I'd go in (back-up your current map before messing with that if that is an available feature) I'd try that. For now, I'd just focus on your low end though. I think that's the area more sensitive to temperatures and atmospheric levels. The upper end usually has enough "slack" to work anywhere (within reason).
But again, I'm just guessing here. I don't have an EFI Guzzi, so take what I'm saying with a grain of salt. Hopefully someone whom is doing this more frequently will jump in a help you out.
1980 Vespa SI Moped
