Author Topic: LM 2 Front Forks Question  (Read 2928 times)
Dobermann
« on: July 30, 2015, 08:05:32 AM »
Hello,
My LM2 has a different fork plugs then the bikes which pictures I've found on internet. I see the plugs usually have air valves on them, but my ones are different. Do you know what fork plugs are they. Here is a video of my bike. The plugs can be seen in at the very beginning of the video.
https://www.youtube.com/watch?v=eWWTfK7mGP4
Are they some early LM2 forks? I am asking because I am considering FAC dampers. I am afraid that if I order dampers for LM2 they wont fit on my forks since they look not adjustable and they dont look like the 'standard' LM2 forks.
Thank you.
« Last Edit: July 30, 2015, 08:10:53 AM by Dobermann »
Offline mtiberio
    • TiberioRacing
Re: LM 2 Front Forks Question
« Reply #1 on: July 30, 2015, 10:19:23 AM »
nice video, too bad it doesn't show more of the FORKS.
top caps look custom made to me.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Dobermann
« Reply #2 on: July 30, 2015, 10:40:06 AM »
Thank you, mate. Yes, I ment the plug bolts that are on top of the fork tubes. There are no air valves. The bike came like that from Germany.
« Reply #3 on: July 30, 2015, 12:22:19 PM »
I have a CX100, same as your LM II w/a SP motor.  It has plug caps w/a recessed hex bolt in the middle for the fork/shock cartridges.
« Last Edit: July 30, 2015, 12:24:40 PM by Arizona Wayne »
« Reply #4 on: July 30, 2015, 01:11:34 PM »
Without taking them to bits you won't know what's going on but they ain't stock.
The caps with a Schraeder valve on top are almost certainly FAC dampers, a common aftermarket swap-out to replace the horrible Sebaceous originals.
« Reply #5 on: July 30, 2015, 01:30:24 PM »
That's funny since I have over 110K miles on my original `81 cartridges, even pulling a sidecar, and they still work just fine, IMHO..........or maybe I replaced them with the same kind and don't remember.  Did replace some cartridges but think those were on my `80 Convert. I had.   :undecided:
« Last Edit: July 30, 2015, 04:30:32 PM by Arizona Wayne »
Offline guzzista
« Reply #6 on: July 30, 2015, 02:29:13 PM »
Looks like regular ol' Guzzi 35mm forks on 195mmm triples with some ( custom?) homemade caps. The camera action  goes to the rear of the bike too fast to highlight the forks . BTW , Mike, got your old race bike Marzocchi forks on my LM
« Last Edit: July 30, 2015, 02:31:27 PM by guzzista »
