Author Topic: Rebuilt two stroke refuses to start - I am stumped!  (Read 23280 times)
Re: Rebuilt two stroke refuses to start - I am stumped!
« Reply #60 on: August 06, 2015, 09:29:00 AM »
The manual calls for setting the Point of ignition to between 3 and 2.5 mm Before TDC depending on that gas you are using.
I don't know what the stroke is on your engine, but with a Kawasaki 350 triple, 2.6mm before TDC corresponds to 23 degrees before TDC.
Irutt, are you possibly confusing mm before TDC with degrees before TDC?
nunzio
« Reply #61 on: August 06, 2015, 10:08:12 AM »
Thanks Triple Jim.!!!
I am going to pick-up a '74 Suzuki GT750 tomorrow and I've never had a two stroke before ,so, I've been looking at how they work and trying to figure out what you guys were talking about.
The TDC confusion in now cleared up in my pea brain Thanks to you.   :thumb:....Alan
« Reply #62 on: August 06, 2015, 10:08:19 AM »
Slow combustion requires allot of advance.
23 degrees doesn't seem like a lot, compared to 4-strokes that typically have 30-40 degrees at running speed.
« Reply #63 on: August 06, 2015, 10:10:58 AM »
Hey, congratulations!  That's a cool old 2-stroke that has a lot of potential if you want to play with it, and is a great touring bike in stock form.
Offline 265coupe
« Reply #64 on: August 06, 2015, 06:40:48 PM »
I don't think that it's been covered yet but it might be worth checking the exhausts. I've had a couple of small capacity 2 strokes that have had fully or partially blocked exhausts that will not run. A wasp built a nest in the muffler outlet of one and that engine would not fire. Broke up the mud blockage and fired straight up. On another the spark arrester screen was blocked with carbon and that engine would only just idle and die when asked to rev. It's a long shot on a twin but maybe worth looking at if you haven't already. Good luck.
erik_w
« Reply #65 on: October 04, 2015, 04:32:05 PM »
Mystery has been resolved!
Just as we suspected - it was low compression that was the culprit! After taking the cylinders apart again and having them rebored properly together with oversize pistons the compression is finally up to spec.
130 psi read cold and now the bike starts up on the first kick!
With 80 psi it simply refused to start at all and with 130 it starts every time.
I hope this can serve as a cautionary tale - have your cylinders done properly and not sloppily and save time!
Offline Groover
    • Scooteropolis
« Reply #66 on: October 04, 2015, 05:17:48 PM »
Great! Thanks for the follow-up. I have been wondering about this. Glad you worked it out, and this is good to know. I've started 2-stoke engines with hardly any compression, so this is a learning experience for me too.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Kentktk
« Reply #67 on: October 04, 2015, 10:50:16 PM »
no, there �s nothing to stop it from working, no sidestand kill function or anything like that.
No, i didn't curse the bike at all in fact - bad manners!   :grin:
I guess the question is really this:
If compression is only 80 psi - will this make the bike impossible to start during anything condition or only given that the crankcase preassure is ALSO too low?
It didn't start even with a drop of gas down the spark plug hole.
I told you that on July 31st post #16. Happy you got it fixed though.
« Reply #68 on: October 05, 2015, 04:36:18 AM »
  Just an odd thought but, could the cylinders be out of round?  If that were so, oil in the cylinders would give compression but as soon as it burned away the engine would die.
