Author Topic: Where Does This Spring Go (Sport 1100 Forks)?  (Read 2971 times)
Offline Dimples
« on: August 01, 2015, 12:37:22 PM »
Does the spring go on top of the washer or below the washer?
'96 Sport 1100
'71 Ambassador
'81 V50 Monza
'83 850 Le Mans III
'85 Le Mans 1000
'04 V11 Le Mans Nero Corsa
'77 850 T3
Re: Where Does This Spring Go (Sport 1100 Forks)?
« Reply #1 on: August 01, 2015, 12:54:34 PM »
I'd say the marks on the indication disc (triangle indicator) are your clue if it matches. Look to corresponding marks on the underside of the dial.
Todd.
Offline Dimples
« Reply #2 on: August 01, 2015, 01:11:50 PM »
Todd.
Those marks on the top surface of the washer (disc) could also be from the rotating knurled indicator cap. The spring was between the two. I just want to confirm that's were it should be. It also fits below it. These forks have been apart in the past, but not by me. The spring is not pictured in the parts manual illustration.
'96 Sport 1100
'71 Ambassador
'81 V50 Monza
'83 850 Le Mans III
'85 Le Mans 1000
'77 850 T3
Kentktk
« Reply #3 on: August 02, 2015, 12:13:28 AM »
Spring small end down first, then washer, followed by the knob
