Author Topic: LM3 Triple Tree Torque Specs.  (Read 2971 times)
Offline Vince in Milwaukee
« on: August 06, 2015, 07:44:32 AM »
Looking to confirm the torque specs. on my LeMans 3.  Found a chart for the old school V7 Sport, T, and T3 showing 32ft/lbs top and bottom.  Going to guess that mine is about the same.  Remember seeing something on this site stating that while these are critical fasteners, you don't want to over do it as the bolt holes are very easy to strip out.
Gone but not forgotten:
Online Chuck in Indiana
Re: LM3 Triple Tree Torque Specs.
« Reply #1 on: August 06, 2015, 07:52:16 AM »
You'd probably be surprised at how little torque it takes to hold something like that. I just snug em up by hand, but not everyone's hand is calibrated the same. :smiley: 36 ft. lbs. is quite a bit...
Offline Groover
    • Scooteropolis
« Reply #2 on: August 06, 2015, 08:57:26 AM »
I was told that it's 32lbs according to Guzzi restoration for all heavyweight twins. I used antiseize on mine (81 G5), so I ended up doing 25% less torque so around 24-26lbs-ish. I'm always stressing when it comes to tightening bolts and such; I've stripped way-way to many in my lifetime..
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #3 on: August 06, 2015, 09:58:52 AM »
Thanks Chuck and Groover for the fast replies.  I went with 30 ft/lbs. on each because I stripped out one on my BMW and now am a bit gun shy.
Kentktk
« Reply #4 on: August 06, 2015, 10:15:16 AM »
Stripping isn`t the only concern you can break the clamp opposite the bolt side also.
