Author Topic: eldorado 850 oil pump gear wont pull off  (Read 4157 times)
Eldo73850
« on: August 08, 2015, 12:45:17 PM »
I am at my wits end i am trying to get my oil pump gear off my 850 eldorado im restoring the entire thing and that damn thing wont come off for nothing i have tried all different pullers and even have bent a few any ideas?
Offline NCAmother
Re: eldorado 850 oil pump gear wont pull off
« Reply #1 on: August 08, 2015, 01:31:13 PM »
did you try removing the key?
Howdy
Eldo73850
« Reply #2 on: August 08, 2015, 01:46:48 PM »
I dont even see a spot for a key its the very bottom gear of the three in the front
Eldo73850
« Reply #3 on: August 08, 2015, 01:59:36 PM »
I guess the question is how do i remove the key when i cant see it or even access it if its where i think it is the little tiny notch
Offline NCAmother
« Reply #4 on: August 08, 2015, 02:01:19 PM »
If you look at the gear where it slides on the shaft, there should be a key that holds the gear from spinning. The shaft and the gear should be slotted for the key
Howdy
Offline NCAmother
« Reply #5 on: August 08, 2015, 02:05:37 PM »
The key should be in that tiny notch, hopefully it's not banged up to prevent easy removal.  Is the gear tight on the spindle or loose?
Howdy
Offline Hahnda
    • Scrambler Cycle
« Reply #6 on: August 08, 2015, 02:25:25 PM »
The earlier bikes had a tapered shaft and you can't see the key. Later bikes were a straight shaft.
Have you tried heat?
1949 GTV - 1948 Airone
www.scramblercycle. com
Offline twhitaker
« Reply #7 on: August 08, 2015, 02:27:51 PM »
The key is a Woodruff type. If it rotates in the shaft the corner may hang up in the gear keyway.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
« Reply #8 on: August 08, 2015, 02:47:07 PM »
My standard cure for this is to get my 3-jaw puller on it tight and then pop the shaft of the puller with a smart blow from a 'live' hammer (not a deadblow -- I like a traditional ballpeen).  If it's nice and tight and you pop it smartly, the problem becomes catching the stuff before it hits the floor.
If the key has become bound this will be more of a challenge.  Someone asked if the wheel is loose or tight on the shaft . . .  this is an important detail.
Offline acogoff
« Reply #9 on: August 08, 2015, 04:45:17 PM »
     Could be some Einstein put red loctite on it at assembly. A burns-o-matic should not get things too hot to hurt anything, but use your head. Had some fool do this to a tapered pump shaft on a JD combine. Swearing seems to help too.
Marshall County Minnesota USA
« Reply #10 on: August 08, 2015, 04:53:41 PM »
Even worse, the green stuff for cylindrical bonding. I agree, though.. heat it to 400 and try pulling it again.
