Author Topic: Stelvio Oil Alternatives  (Read 36445 times)
56Pan
Re: Stelvio Oil Alternatives
« Reply #30 on: August 10, 2015, 11:41:32 PM »
The comment about oil cooling jets in diesel engines reminded me of a problem I had with a replacement diesel eng. in my Chevy pickup.  NGC here.  The new eng. was the later mil. surplus model and had oil cooling jets.  The company I bought it from had put on a new stock oil pump for the earlier style engines with no piston oil cooling jets.  My oil pressure was_way_down until I put the later pump on.  Apparently, on a GM 6.5 diesel V8, the piston oil cooling jets really flow. The pump gears were at least half again bigger than the earlier pump.  Good to know, at least to me, that my Norge engine is so designed.
Offline Larry
  • Escape Reality At Any Cost I Say
    • Melbourne West Church
« Reply #31 on: August 12, 2015, 12:00:15 AM »
Any oil that meets the specs. I use Penrite Ten Tenths premium ten 10/60. It does its job. So do many others.
Thanks Pete
Larry
2002 Stone 1100 - Gone
2005 Breva 1100 - Gone
2012 Stelvio 1200 8V ABS - Gone
2013 Sport 1200 8V ABS - Current
Offline kidsmoke
« Reply #32 on: August 12, 2015, 01:43:33 PM »
so if ya'll had a Jackal running like a top, with no knowledge of the contents of the oil pan, with 25k on the clock, and 3 liters of 20W50 and 3 liters of 10W60 full syn on your bench, what would put in the motor.
 :boxing:
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
« Reply #33 on: August 12, 2015, 01:45:32 PM »
 :boxing:
I'd have a look at the owner's manual first.
« Reply #34 on: August 12, 2015, 01:57:04 PM »
Because then there would be nothing to talk about.   There would be no more "Local rider and Mom in your town finds this one weird secret way to make your engine last longer".    No more "Insane oil tipz - Must See!".
Use a good quality 10W60 oil and change it every 10K km like the book says.   No one has ever found a way to make an engine last longer or run better doing anything else.
But for some reason people say "My opinion is that I should use ..."  or "I only use ...." or "I can get Rectum 20W50 at my local Dollar General so I'm sure that 20W50 is OK ...".    The busy man in brown shorts will bring a year's supply of any oil you want right to your door in two days, so "availability" is never an issue.
Just something to talk smack about ... Nothing wrong with that, I suppose.
If anyone wants Rectum 20W50, I'll ship it to them by the gallon or quart for free, no skimping on the volume either.
Comes with a nifty pour spout, a handi-rag and litmus paper to test the viscosity to prove you aren't being cheated. Please specify if you want the clear or milky white jugs. I can put them on the weekly re-order plan too, no extra charge. And, for a limited time, no need to order two, its an automatic order 1 get 2.
Offline kidsmoke
« Reply #35 on: August 12, 2015, 03:28:42 PM »
noted. manual not present
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
« Reply #36 on: August 12, 2015, 03:48:04 PM »
In this modern world, everything is ALWAYS present.
I typed in "Moto Guzzi Jackal Users Manual Oil" and was immediately directed to the "This Old Tractor" site
http://www.thisoldtractor.com/mg_manuals/workshop_manual_california_update_en_de_ne.pdf
which has a PDF copy of the Jackal users manual.   On page "4" it tells you to use AGIP 4T SAE 5W40 in the engine.
25 seconds, info received, and it's NOT 20W50 or 10W60 that is recommended, so a good job you asked.
Online bad Chad
« Reply #37 on: August 12, 2015, 04:23:51 PM »
Of course Lannis, you know that recommendation in the owners manual has been superseded by a subsequent informational release.
That release has been posted to this web site many times.  From my memory the Jackal is spec'd 20w50.
1988 YX600 Radian
« Reply #38 on: August 12, 2015, 04:35:10 PM »
Well, see, you not only get the original information BUT you get the informational release updates, all right here on the site at your fingertips and all within a few minutes .... paper manuals and dealer information not necessary.
But are you really sure about that "informational release" that has been posted "many times"?    Can you find one for us?
« Last Edit: August 12, 2015, 04:41:04 PM by Lannis »
Offline kidsmoke
« Reply #39 on: August 12, 2015, 04:35:54 PM »
good points (re: in this modern world)
and thanks for the effort and the info.
I intended it as something of a rhetorical question...given the contents of this thread...kinda saying...ok then, given all this information, IF you found yourself in this situation, what would you do?
to your first point, it reminds of a line I saw somewhere:
I possess a device, in my pocket, that is capable of accessing the entirety of information known to man. I use it to look at pictures of cats and get in arguments with strangers.
 :bike-037:
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
« Reply #40 on: August 12, 2015, 04:43:27 PM »
 :bike-037:
Yup, that's what most people do with them.
But your question could also be:
"I have 5 quarts of kerosene and I have 5 quarts of chain-saw bar oil.    Which one should I put in my motorcycle?"
Sounds sort of like "Just answer yes or no - Have you stopped beating your wife?"   Neither of the allowed answers is any good, so maybe the answerer can suggest another ... ?
Offline DAM650
  • DAM650
  • ain't conversation if you're doing all the talking
« Reply #41 on: July 03, 2025, 07:14:24 PM »
I got motul 8100 x power 10w60.
Guessing that should be fine
Previous owners running liquid moly
Anyone object?
2013 NTX
2002 R1150R
2002 F650GS
« Reply #42 on: July 03, 2025, 08:08:13 PM »
Man oh man, nobody ever reads my posts.  Here it is straight from the factory. manual specs have been superseeded.  Read the chart.
Offline kballowe
  • - Kevin the Great -
« Reply #43 on: July 03, 2025, 08:30:37 PM »
hahahahaha - oil threads never die.  This one is ten years old.
 :boozing:
« Reply #44 on: July 04, 2025, 12:08:01 AM »
 :boxing:
I would use the 11W60 that's what's specified for the V7
