Author Topic: Help to Remove Steering Stem on T4 Model  (Read 15871 times)
Offline JoeW
    • The Guzzi Doctor
Re: Help to Remove Steering Stem on T4 Model
« Reply #30 on: August 11, 2015, 09:19:53 PM »
To get that lower bearing off, I use a chisel and split the bearing cage, it gets all the rollers out of the way. Now you can clamp the lower clamp in a vise with soft jaws, and drive the race off using the chisel against the upper lip on race. You can warm the inner race with a propane torch, most of the time it's not necessary
Joe Walano
Offline SED
« Reply #31 on: August 11, 2015, 09:21:45 PM »
Hi Don,
Congrats on getting it apart.  I replaced the seals and cartridges in both the LMIII and Monza and they were very similar.  If the T-4 is the same the second page of this topic may help:
http://wildguzzi.com/forum/index.php?topic=75441.30
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Offline Guzzi_Don
« Reply #32 on: August 11, 2015, 10:23:35 PM »
Hi Don,
Thanks Shawn,
That link did show some interesting stuff on how to dismantle the fork tubes for rebuilding.
Cheers
Cheers
Don
1981 Moto Guzzi 850-T4
1977 Suzuki GS550/700
1991 Suzuki VX800
Offline Guzzi_Don
« Reply #33 on: August 12, 2015, 07:13:30 AM »
Tonight I completed the last little bit on the steering stem disassembly. I removed the lower inner bear that was on the lower end of the steering stem. I prised the bearing retainer outwards until I had distorted it enough to snip it with the tin snips. Then pulled it away so all the rollers could fall out. With that removed I then  took to the inner race that was pressed onto the stem with a small angle grinder. I only had a cut-off wheel though and not a wider grinding wheel which would have made the job easier.
I persevered with the cut-off wheel and went a bit deep in a couple of places but got it off in the end. See following pics.
Now I am waiting on parts to arrive before I can do any more work. Or maybe I could pull the front forks apart and see how they work.
All good times ahead.
Thanks for all help offered.
Cheers
Don
1991 Suzuki VX800
Offline Yeti
« Reply #34 on: August 12, 2015, 10:33:23 AM »
The only other way is to press the shaft out of the lower tripple clamp, the hammer approach will only knacker the threads or bend the shaft. Guess how I found out.
dibble
« Reply #35 on: August 12, 2015, 12:53:27 PM »
Does the stem come out of the Yokes on these, it dosen't on Californias, I found out the expensive way.
« Reply #36 on: August 12, 2015, 01:11:56 PM »
I knew a piece of wood on top would work, sure you prob mangled that wood but it's a hell of a lot less danger of damaging the steerer than even brass plate  :thumb:
I have done the same on several old bicycles when I was wrenching at the co-op and it always worked fine.
and to Chuck  :whip2:
« Reply #37 on: August 12, 2015, 01:19:06 PM »
Meh, he was just lucky..  :evil: :grin:
Offline Guzzi_Don
« Reply #38 on: August 12, 2015, 03:10:52 PM »
I would say talented and resourceful.  :bow:
Cheers
Don
1991 Suzuki VX800
