Author Topic: ill handling loop  (Read 2228 times)
Offline nbags
ill handling loop
« on: August 11, 2015, 05:33:17 AM »
1971 ambo started handling horrible on turns,also wobble lower speeds found the upper triple tree plate crack around the center bolt ,the crack is just around the spacer that was welded to plate.Is it ok to weld back on?What is the max radial run out of a front tire .070 too much.
Online Chuck in Indiana
Re: ill handling loop
« Reply #1 on: August 11, 2015, 07:12:46 AM »
I'd look for another one and Yes. :smiley:
Offline JoeW
    • The Guzzi Doctor
« Reply #2 on: August 11, 2015, 08:47:51 AM »
I have a spare upper plate. PM me if interested.
Joe Walano
