Author Topic: 13 3/4" shock on Tonti frame  (Read 3659 times)
nunzio
« on: August 11, 2015, 04:42:34 PM »
A friend has a new pair of.. 13 3/4" eye to eye... Koni Shocks that he will give me to use on my '84 Cali II.
Mine are kinda tired.
Has anyone used a pair that tall?
The shocks on my Cali II are 13" eye to eye.
Any advice is welcome......Alan
Online Chuck in Indiana
Re: 13 3/4" shock on Tonti frame
« Reply #1 on: August 11, 2015, 05:40:12 PM »
I was thinking that 13 1/2" was the normal length? Of course, my memory is about as long as my... oh never mind.
Offline balvenie
« Reply #2 on: August 11, 2015, 07:02:02 PM »
          nunzio,
My copy of Guzziology, Version 7.0, p. 21-7, tells me that your standard length is 13". Don't know what allowance is made for pre load. Also don't know if your model's standard shocks had a pre load feature. Mine bike did not but it is an '04 model.
Oz
04 Cali
Offline Idontwantapickle
« Reply #3 on: August 11, 2015, 07:18:22 PM »
Alan,
Measure yours with the bike on the stand, rear wheel off the ground and compare. I stay away from altering shock length for a variety of reasons. The 2 biggest would be that altered geometry will change the handling (could be positive or negative) and an increased swingarm angle may cause increased wear on the U-joint.
Sometimes free isn't free in the end.
YMMV as will the opinions of others.
 :popcorn:
Hunter
P.S. If your Cal has Konis they can be rebuilt.
« Last Edit: August 11, 2015, 07:19:18 PM by Idontwantapickle »
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #4 on: August 11, 2015, 07:26:17 PM »
          nunzio,
Preload won't change the length of the free standing shock, only the length when it is loaded.
Offline Petrus Rocks
« Reply #5 on: August 11, 2015, 07:38:33 PM »
A longer shock will make the bike steer quicker- less effort needed to change directions.  On my '85 Cal II cafe build I lengthened the rear shocks by an inch.  I noticed more positive response, quicker steering, a little more feedback through the bars.  Even so the change was small-15%  They're free-see what happens.
« Reply #6 on: August 11, 2015, 08:22:57 PM »
And if you don't like them I'll try them  :D
Offline balvenie
« Reply #7 on: August 12, 2015, 03:54:18 AM »
Thanks Dave :grin:
Oz
04 Cali
Offline gfritzmeier
« Reply #8 on: August 12, 2015, 09:08:58 AM »
I'm in the process of buying some Showi shocks that are only 1/4 inch longer than my 13" shocks so I assume the difference will not be noticeable. What say you?
Ya don't have to believe everything ya think!
Ride All Day,Play All Night!
