Author Topic: spring dimensions  (Read 2325 times)
Offline gfritzmeier
spring dimensions
« on: August 13, 2015, 11:48:49 AM »
I've got a 2003 Cal. Aluminum and was wondering if anyone out there knows what the dimensions are for front suspension springs are?????????
Ya don't have to believe everything ya think!
Ride All Day,Play All Night!
Offline gfritzmeier
Re: spring dimensions
« Reply #1 on: August 13, 2015, 03:18:31 PM »
Reason I'm wondering is I'd like to put Progressive springs. I've got an 2003 Cal. Aluminum and don't know which ones to buy.
Offline balvenie
« Reply #2 on: August 13, 2015, 08:04:47 PM »
I could not find a table of dimensions in Guzziology. Don't know if your bike and mine share the same springs. Mine is '04 Cali EV.
Length 14.75" or 375mm   These could have compressed in service.
Outside Diameter    1.515"   or 38.5mm approx
Wire Thickness   0.215"   or 5.5mm approx
Note      Imperial measurements for the last two are more accurate
Hope this helps mate.
Oz
04 Cali
Offline gfritzmeier
« Reply #3 on: August 14, 2015, 11:20:55 PM »
I thank you friend. Not sure if they are the same but I'll check that out.
