'03 Breva Front Forks. Would like To Modify.
Topic: '03 Breva Front Forks. Would like To Modify. (Read 2335 times)
Muzz
On the backside of the planet.
August 14, 2015, 05:05:43 AM »
My old Matchy had a drain hole at the bottom of each fork slider. Made it real easy to drain the oil out of the forks.
Would any one know if the alloy is thick enough on the Marzocchi's to allow for a hole to be drilled and tapped down at the bottom so the same oil drain procedure could be used. A helluva lot easier than taking everything to bits simply to get the oil out.
sign216
Re: '03 Breva Front Forks. Would like To Modify.
Reply #1 on:
August 14, 2015, 06:43:38 AM »
On the yahoo group
https://groups.yahoo.com/neo/groups/MG_750/info
we churned that issue over a couple years ago. How to make changing the fork oil less of a chore.
We explored a lot of options. Some a little crazy, like using some internal retaining bolts as a path for the oil to escape.
In the end, we need a pair of donor forks for experimentation. Don't you think?
Last Edit: August 14, 2015, 06:44:22 AM by sign216
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Muzz
Reply #2 on:
August 14, 2015, 10:50:00 PM »
That would be really great if a donor set was available, however, I have not seen too many Breva's wrecked out here. Did not really want to experiment on my own ones without having someone who has been down that road before.
