Author Topic: Tubeless?  (Read 3220 times)
Offline wymple
Tubeless?
« on: August 14, 2015, 10:33:36 PM »
Has anybody gone tubeless on the front of a Callifornia II? I did it on a couple of bikes, the rear of my GS850 Suzuki and one end (can't remember which) of my son's 1984 V65. I need a front tire and the conversion is easy if the rim doesn't mind. Wondered if it's been tried successfully.
Re: Tubeless?
« Reply #1 on: August 14, 2015, 11:16:03 PM »
I went that way on my Cali II about 6 months ago. I had to file a flat on the inside of the rim where the valve fits and drill it out a little larger for the valve.
So far I have never had to add air.
BTW they were done at a shop so I never had time to clean the place where the bead sits properly but it sealed perfectly.
My spoked Eldorado was another story, had a few leaks in the front but it seems good now touch wood.
« Last Edit: August 14, 2015, 11:17:31 PM by Kiwi_Roy »
Offline wymple
Re: Tubeless?
« Reply #2 on: August 15, 2015, 02:45:45 PM »
That's what I needed to hear. I did this in the spring on the back wheel of the V65, no problems, and on the back of my Suzuki.  I had to drill the valve stem holes out to match the stems, which are found at any of the big box auto parts stores. I don't want to mess with the tube unless I have to, I tend to find holes when I'm done :angry:
Online Groover
    • Scooteropolis
Re: Tubeless?
« Reply #3 on: August 15, 2015, 03:20:39 PM »
Search this part number for a stem to use without drilling.
VS-1218R
There is also a NAPA equivalent but I don't have the number handy.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline wymple
Re: Tubeless?
« Reply #4 on: August 15, 2015, 04:34:50 PM »
Ooooooh, thank you very much. Didn't know there was such a part!
Re: Tubeless?
« Reply #5 on: August 16, 2015, 08:28:21 AM »
Another option is a Tank Valve, these are a Schrader fitting with 1/4" NPT male thread.
You would need to tap the wheel and I have only seen them in brass.
