Author Topic: Oil change from hell  (Read 13751 times)
Offline atavar
Re: Oil change from hell
« Reply #30 on: August 19, 2015, 04:07:42 PM »
Noted.  I will use more line spacing next time.  ;)
« Reply #31 on: August 19, 2015, 04:15:37 PM »
On your oil change BTDT many times.  :grin: If you ask me in person, I'll deny it.  :rolleyes:
« Reply #32 on: August 19, 2015, 04:23:23 PM »
There is no magic to figuring out how much oil is needed for an oil change. If the Norge's oil is at the proper level before the oil change, just add the same amount back in minus a very small amount and that is all it takes.
The method is rather simple. Drain the oil including that from the filter into a 4 liter (or 1 gallon) jug from a previous oil change. Mark the height and transfer that to the new one. Drain the new jog to match the line.
Fill the Norge after the drain and go ride it for the prescribed time. Check the oil and adjust as needed.
No going back and forth checking numerous times. It is a 1,2,3 done thing.
No, the filter will not retain enough oil after emptying it to make enough of a difference that you can't go out and ride it to check properly and adjust. You simply put a small grate over the pan into which you drain the oil and let it sit for a while. What little oil will be retained in the filter is practically nothing.
Then going forward you have a nice job from which to measure the amount needed and there is no guessing or adding/checking/adding/checking to bother with.
The very best thing you can do is to not pay attention to oil threads, seriously, as other than a cross reference for alternative oil filters, all the stuff about this weight and that weight doesn't help you. Use the weight prescribed, the type prescribed and be done with it.
Offline bratman2
« Reply #33 on: August 19, 2015, 06:26:41 PM »
Had so many moments just like yours. You explained it much better. On the oil seems like I use 3qts. and 8ozs. That puts me in the middle of the dip stick and I never have any oil in the air box.
Glenn Taylor
09 Norge with Staintune and Rexxer reflash
87 Subaru Brat (owned since 97)
