Author Topic: Guzzi should make something like this  (Read 12872 times)
Offline El Pescador
Re: Guzzi should make something like this
« Reply #30 on: August 17, 2015, 08:01:15 PM »
I will apologize in advance, so I am sorry.
Meh.
That front cylinder looks like a real good candidate for hydraulic lock on start up.....but I'm sure they've already taken care of that.
kjf
School me.  Why hydro lock?
Fair winds and following seas
« Reply #31 on: August 17, 2015, 08:29:14 PM »
Rather have something uplifting instead.  :boozing:
For us winter shut-ins: A Virtual Guzzi on a Google Earth tour adventure!
 :popcorn:
« Last Edit: August 17, 2015, 09:01:41 PM by Penderic »
« Reply #32 on: August 17, 2015, 10:53:28 PM »
Fluid slipping past a downward facing piston's rings to get caught in the compression cycle and finding itself un-compressable. Takes a couple of somethin's tripping over a couple of wear/use scenarios to occur... But, occur it does from time to time.
Seems like I heard about well worn flyin' bricks sitting hot on side stands offering this up though could just have been bench gas or social media pollution being spread.
Todd.
« Reply #33 on: August 18, 2015, 12:28:16 AM »
kjf
They have a "total loss" oiling system that drops the excess oil down a tube and on to the ground. :wink:
Seriously though,  how did those WW11 radial engines get around the problem?
« Reply #34 on: August 18, 2015, 07:05:56 AM »
SOP on a radial is to pull the prop through by hand for as many blades as there are cylinders if it has been sitting for a length of time. If there is a hydraulic lock, pull a plug and drain the oil out of the cylinder. Failure to do this will end up in a bent rod.
Joe A.
« Reply #35 on: August 18, 2015, 11:01:53 AM »
I guess what I was getting at was, here is a small company in France creatively using an unusual engine layout.  Guzzi could do something similar, after all, they have built just about every engine configuation since 1921.
A flat twin like this, an L-twin, a laydown triple - there are lots of ways they could retain their reputation for building funky, durable bikes while building something that would satisfy emissions requirements.
Personally, I would like to see a 650cc laydown, 4 valve OHC single, about 50HP, standard riding position and with a little more ground clearance than the NF, and perhaps a bash plate.  Naturally, it would have to have a whacking great external flywheel, with the emphasis on torque, not revs.  Yes, a Nuovo Nuovo Falcone.  Two or three of us might buy one.......
Nick
Last paragraph almost describes my NC 700x.
Offline Yukonica
« Reply #36 on: August 18, 2015, 10:00:52 PM »
Steampunk motorcycle.
I was waiting for Penderic  to uptake on the steam punk theme _ far more funny than I.
 But as it goes:
http://img.wonderhowto.com/img/original/87/10/63498356421532/0/634983564215328710.jpg
is the preferred touring attire.
« Reply #37 on: August 19, 2015, 12:22:12 AM »
Kind of makes you want to be an infant........ :grin:
