Author Topic: fuel pressure regulator blowing fuel , 98 cali ev  (Read 2603 times)
Offline arveno
    • ddleathers.com
« on: August 16, 2015, 01:37:31 PM »
Like title says , fuel pressure reg is blowing fuel.( worked fine until today , of course )
Does it need to be replaced ? ( of can be fixed ? )
where can i find a new one ? does anyone have the part # ?
thanks
Marco
Online Wayne Orwig
Re: fuel pressure regulator blowing fuel , 98 cali ev
« Reply #1 on: August 16, 2015, 02:17:50 PM »
Is the fuel coming out the opened vent tube?
If so, yes, you need a new regulator.
Offline arveno
    • ddleathers.com
« Reply #2 on: August 16, 2015, 03:00:24 PM »
yes.
any side of the road temporary fix ?
« Reply #3 on: August 16, 2015, 08:10:49 PM »
You could find a car one, I think most injector systems run at 40 psi, even if it's 5 psi different it will still work.
If it's only leaking a little bit add some tubing and run it into a container.
« Last Edit: August 16, 2015, 08:12:35 PM by Kiwi_Roy »
Online rodekyll
« Reply #4 on: August 16, 2015, 09:21:44 PM »
There is an adjustable inline "JDM" style you could substitute.  You'd have to figure out the return -- maybe put a barb where the current regulator is.  They cost ~$30.
Here's an example from ebay.  they are also available from most auto parts stores.  I have one on the trike.  Easy to dial in the pressure
http://www.ebay.com/itm/UNIVERSAL-JDM-RED-ADJUSTABLE-FUEL-PRESSURE-REGULATOR-FPR-WITH-PSI-GAUGE-/281548004482?hash=item418d919c82&vxp=mtr
