So, dropped my bike off at the stealer (still under warranty, so I'll let them get greasy), but want to ask for some thoughts:
I've got a rear hub leak, intermittent. it's NOT diff. fluid, as I"m only 800 km from my fluid change and that stuff is dark... the leak I have is amber/golden.
No rhyme or reason to when it decides to drip, sometimes it simply makes the lower section of my hub a little oily, others, I'll come out to find it's puked on my rim and tire.
I'm thinking it's a seal around the shaft, but is the shaft in an oil bath? I thought it was dry. Plus, if it's a leak from the transmission... that's a long way to travel, to drip out the hub, no?
