Author Topic: Clutch Not Disengaging - Solved  (Read 2419 times)
Offline geodoc
« on: August 26, 2015, 12:49:18 AM »
Finally got the clutch apart on my 1000SP engined Loop to see what was causing the disengagement problem from a week ago. I was gob-smacked to see this when I pulled the plates out. The bolt head was apparently rattling around and would sometimes jam one side of the pressure plate & prevent disengagement. Never seen this happen before.
All the bolts were installed new from MG Cycle & torqued with a Snap-On digital torque wrench.
I'll be replacing them all & hoping that they last a bit longer.
Re: Clutch Not Disengaging - Solved
« Reply #1 on: August 26, 2015, 12:57:41 AM »
Did bolt George. Rare but it happens. PITA that it happened deep inside.
Offline geodoc
« Reply #2 on: August 26, 2015, 01:02:05 AM »
Kinda strange. I assume poorly heat treated or somesuch. Hope the replacements are better.
Sigh ................... ..
« Reply #3 on: August 26, 2015, 04:15:16 AM »
Some guys are just hard on equipment  :grin:
