Possible re-wire to use directionals as running lights and blinkers
Topic: Possible re-wire to use directionals as running lights and blinkers (Read 3365 times)
giusto
Giusto il canne del Como
August 27, 2015, 08:11:31 PM »
Hello,
I have a 2001 Jackal and was wondering if there is a re-wire or retro fit flasher switch that will allow the use of directionals as running lights and blinkers?
Thanks for the help!!!
btw I spent a few hours in the Guzzi museum in Mandello a few weeks ago and it was freeking amazing...no AC and about 125 degrees on the 3rd floor but still amazing.
Giusto
2020 V 85 TT Travel
76 V1000 Convert Mr. Slate
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
rodekyll
Not my real name
Re: Possible re-wire to use directionals as running lights and blinkers
Reply #1 on:
August 27, 2015, 08:22:47 PM »
Replace the oem with a 3-wire, amber LED die. You'll have essentially an '1157' type tail light bulb when you're done -- 'tail' mode is a marker light 'brake mode' is your blinker. It will require a timer-based ass opposed to load-based flasher. I do this all the time -- no point in having a perfectly good amber housing that's not lit up all the time.
giusto
Reply #2 on:
August 27, 2015, 08:36:33 PM »
wow a speedy reply....thanks rodekyll.....but can you describe this in a bit more detail....I'm still a little new
2020 V 85 TT Travel
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
wrbix
Reply #3 on:
August 27, 2015, 09:10:28 PM »
I've used these on my BMW airheads - makes rear running lights, might work on front too???
http://www.soundoffrec.com/products/lights.aspx
Bill in VA, sometimes FL
"Eschew aphorism"
LeMans IV - "Giulia"
Lario - "Giulietta"
V50III cafe'd - "Leggera"
‘77 Convert - “Sofia”
Classic Mini
‘60 Austin Healey Sprite
Caterham Super Seven Sprint
‘13 Audi TTRS
Grumman AA5B (sold)
eldoroddo
Reply #4 on:
August 27, 2015, 10:28:31 PM »
I use the Hopkins run-stop-turn converter on the red-lense Grote lollypop lights on the rear of my Eldo.
Gives me normal turn signals, three running lights, three brake lights and is very noticeable.
Available at Wally World and Pep Boys.
rodekyll
Not my real name
Reply #5 on:
August 27, 2015, 10:46:00 PM »
I use LEDs like these (lots of sellers) when the socket and all is ruined, although I'm building them into my trike's new model A tail light housings.
They're about a $0.25-cent quarter's diameter and house two intensities of (in this case) amber. You feed a third wire into the housing for connection to the headlight or ignition switch. There are four leads on the bulb which make for running light and then a double-bright turn signal. Solder the wire you ran in to the dim side, the turn to the bright side (use a 9v battery to figure that out) and tie the grounds together/connect to existing ground. I glue mine into the old light socket. It wedges in to the socket pretty well. The power drain is negligible and the light is acceptable. You need to change your blinker box for an LED-type or it won't blink proper.
http://www.ebay.com/itm/2-Amber-Yellow-15-SMD-5050-3156-3157-3457-4157-LED-Car-Indicator-Light-Bulbs-/121252587858?vxp=mtr&hash=item1c3b37a952
T in NC
non e il rumore, e la musica
Reply #6 on:
August 28, 2015, 06:28:15 AM »
Auto cancel turn signals too:
http://kisantech.com/mag/index.php/signalminder/sm-5.html
Steve Stamilio
Groover
If it ain't broke, I'll break it.
Reply #7 on:
August 28, 2015, 07:49:23 AM »
I could be wrong, but google Greg Bender at thisoldtractor.com. I believe he shows this conversion done somewhere on his site. Someone does, and it was done on an Eldorado I believe, so possibly someone else and not on his site. It's been a while since I've seen it.
Good luck.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
giusto
Reply #8 on:
September 03, 2015, 08:33:01 AM »
Thanks to the Guzzi hero's....great info I'll post when complete
pace~
Giusto
2020 V 85 TT Travel
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
