Author Topic: U.S. Fines Triumph Over Safety Concerns  (Read 10387 times)
Offline cloudbase
« on: September 01, 2015, 12:05:15 PM »
DETROIT (AP) — The U.S. government has fined Triumph Motorcycles up to $2.9 million for violating safety reporting requirements.
Under an order issued to United Kingdom-based Triumph, the company must pay a $1.4 million cash penalty and spend at least $500,000 to improve safety practices. An additional $1 million in penalties could be levied if additional violations emerge.
Triumph recalled more than 1,300 motorcycles in September 2014 because of a defect that could reduce steering capability and increase the risk of a crash.
An investigation by the National Highway Traffic Safety Administration found that the company failed to report the defect for more than a year.
The company also failed to submit required documents, including injury claims and progress reports on recall repairs.
Re: U.S. Fines Triumph Over Safety Concerns
« Reply #1 on: September 01, 2015, 12:08:32 PM »
So..... THAT'S why I keep crashing my Tiger :grin: :bike-037:
« Reply #2 on: September 01, 2015, 12:54:31 PM »
 Was Triumph aware of the defect , what is it , and were there any accidents because of this issue "
 Oh , and John , Matt doesn't need to know about this  :grin:
« Reply #3 on: September 01, 2015, 01:49:19 PM »
I'm not tellin' him!
« Reply #4 on: September 01, 2015, 01:52:50 PM »
These days, it's equally possible that Triumph management knew there was a problem and tried to hide it (a la Ford Pinto fuel tanks) and our regulators have protected us, or whether some unelected bureaucrat in the DOT is throwing his weight around and hitting the foreign corporation with a Catch 22 over nothing ...
Offline ITSec
« Reply #5 on: September 01, 2015, 02:26:49 PM »
Actually, the DOT and the NHTSA have been on a bit of a tear lately, and have hit quite a number of manufacturers with this same violation - failure to report a problem for which the manufacturer had reports and records. In all the published cases, the manufacturer had enough information reported to them that they knew, or should have known, that a defect existed and that it met the criteria for being reported to the feds. The fine is levied after a review of the manufacturer's records related to the problem. See the reports on the airbags, the ignition switch design, the Fiat-Chrysler 'failure to report and act', and so on. It's part of a major program by the feds to get more responsiveness from vehicle makers.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
« Reply #6 on: September 01, 2015, 02:32:41 PM »
It's likely that you're right in this case.   But there are a growing number of examples of overzealous, over-the-top regulatory enforcement cases that don't even pass the snicker test, especially in environmental and "zoning" situations ....
Offline ITSec
« Reply #7 on: September 01, 2015, 03:01:48 PM »
To be sure... (or for those in Quebec - C'est vrai!)
ITSecurity
« Reply #8 on: September 01, 2015, 03:09:45 PM »
 OK , but what was the problem ?
« Reply #9 on: September 01, 2015, 03:12:44 PM »
Been trying hard to find it on-line and on the NHSTA site, but it ain't easy.
Triumph had a "recall" in 2008 for Ohlins shocks on some of their sport models, and a later one for Speed Triple handlebar clamps that didn't properly cinch down the handlebars.
But this was a "reporting" violation, and may not have made it to the "recall" stage.
Offline ITSec
« Reply #10 on: September 01, 2015, 03:25:45 PM »
The problem with the bikes was the recall in 2014 related to steering, I believe it affected 2012-2013 models. Details of the agreement, fine and background are at http://www.nhtsa.gov/About+NHTSA/Press+Releases/2015/nhtsa-fines-triumph-08312015
ITSecurity
« Reply #11 on: September 01, 2015, 03:30:38 PM »
Yes, all the press releases use the same boiler-plate language:
" ....for a defect that could reduce steering capability and increase the risk of a crash."
I suppose that we gearheads would like to know what the defect was.    Could have been the handlebar-clamp thing, I suppose, or could have been non-properly-heat-treated tube cinch bolts, or anything.
Since Guzzi had the same sort of problem with front ends about 13 years ago, it would be interesting to know if it was a real danger, or if it was a missing warning label ....
« Reply #12 on: September 01, 2015, 03:33:43 PM »
 Still no specifics regarding the safety issue , which indicates that this is a paperwork matter and not a real safety problem . I have no ax to grind with NHTSA , but seems to me they are guilty of not providing all of the information .
Offline ITSec
« Reply #13 on: September 01, 2015, 03:39:55 PM »
Going from the dates referenced, it's likely the actual recall involved was this:
SUMMARY:
Triumph Motorcycles America, LTD (Triumph) is recalling certain model year 2012-2013 Triumph Street Triple and Street Triple R motorcycles manufactured July 1, 2012, to October 1, 2013, and equipped with ABS. In the affected motorcycles, the four bolts that secure the two cable guides on either side of the headstock do not contain threadlock. As a result, the bolts could loosen.
CONSEQUENCE:
If the bolts loosen, steering movement could be restricted, increasing the risk of a crash.
REMEDY:
Triumph will notify owners, and dealers will replace the four bolts with new bolts containing threadlock, free of charge. The recall began on November 7, 2014. Owners may contact Triumph customer service at 1-678-854-2010. Triumph's number for this recall is Service Bulletin 501.
NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
The fine was related to a paperwork problem, the recall (with inadequate notification as required) was related to a real safety issue.
ITSecurity
« Reply #14 on: September 01, 2015, 03:50:38 PM »
 Thanks Cousin  :thumb: Still , sounds like NHSTA is guilty of omitting pertinent info ,
Offline Stormtruck2
  • AKA Scotch and Cigars
  • Geese Fly in a Proper V
« Reply #15 on: September 01, 2015, 03:53:01 PM »
I was trying to turn your Tiger when it bit me. SEE!  It wasn't my fault! :wink:
μολὼν λαβέ-molṑn labé
Offline ITSec
« Reply #16 on: September 01, 2015, 03:55:21 PM »
Actually, the NHTSA website has the details including copies of two notices sent to Triumph warning them they hadn't sent the status reports on the recall. It does take some digging, but I have the background for that...
ITSecurity
« Reply #17 on: September 01, 2015, 04:18:02 PM »
 Good thing there are smart people like you to interpret for folks like me  :bow:
 In one of his books , PJ O'Rourke visits NHTSA expecting to find a bunch of anti car types , instead he found a bunch of gearheads . Think that is interesting and enlightening .
Offline SmithSwede
  • I don't want a pickle
« Reply #18 on: September 01, 2015, 05:03:14 PM »
On the other hand, who can forget Joan Claybrook and the motorcycle which steered by its rear wheel?
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
« Reply #19 on: September 01, 2015, 05:05:09 PM »
 Even her underlings told her that wasn't gonna work  :rolleyes:
bpreynolds
« Reply #20 on: September 04, 2015, 03:01:41 PM »
Just curious, any domestic companies been hit by NHTSA lately?
« Reply #21 on: September 04, 2015, 03:09:34 PM »
 Yep , Chrysler (Jeep) , and GM .
bpreynolds
« Reply #22 on: September 04, 2015, 03:11:17 PM »
Those aren't American made products.
 :wink:
« Reply #23 on: September 04, 2015, 03:22:58 PM »
 :wink:
 Not 'Murican owned , still largely made here , or at least that is their story and they are sticking to it  :grin: Wait , isn't GM still a domestic company , well , besides Buick ?
Offline ITSec
« Reply #24 on: September 04, 2015, 06:24:21 PM »
 :wink:
Umm - we're talking the modern automotive (and by extension, motor vehicle) industry. I think just about anybody in any country can point to a company that is supposedly 'theirs' and say, "waiddaminutt!" Well, except maybe a guy in Dehli talking about Mahindra or Tata  :azn:
ITSecurity
Offline Thunderbutt
« Reply #25 on: September 04, 2015, 07:49:24 PM »
I heard this was all exposed by the NSA while investigating the latest batch of Hillary's emails
Current rides:, 2002 LeMans,  2020 V-85TT Travel, 2019 DR650
« Reply #26 on: September 04, 2015, 08:01:37 PM »
 Nah , "twas exposed by the Keebler Elves , led by Elvis  :laugh:
Offline ITSec
« Reply #27 on: September 04, 2015, 08:03:49 PM »
Don't Be Cruel, Dusty!
ITSecurity
« Reply #28 on: September 04, 2015, 08:14:23 PM »
 Little known secret , Elvis was really made up of hundreds of Keebler Elves working in concert . The reason why he got chubby was because during the '70s there was a decrease in demand for cookies , more Keebler Elves out of work = more Elvis .
Offline ITSec
« Reply #29 on: September 04, 2015, 09:25:51 PM »
Maybe that explains all the cookie crumbs on the Las Vegas Strip - and why we've never managed to get rid of them...
ITSecurity
