Author Topic: Has anyone put EV forks on a LoopFrame?  (Read 3042 times)
Online fotoguzzi
« on: September 01, 2015, 07:52:10 PM »
what does it take?
« Last Edit: September 01, 2015, 07:53:52 PM by fotoguzzi »
Online fotoguzzi
Re: Has anyone put EV forks on a LoopFrame?
« Reply #1 on: September 01, 2015, 08:03:50 PM »
I'm guessing you'd have to slip the fork tubes up in the clamps about 2-3" if using the loop steering stem.. then you could mount some heli bars or even spine frame handle bars above the top clamp.
« Reply #2 on: September 01, 2015, 08:22:53 PM »
Use the EV stuff, make a spacer washer for the one on top of top bearing set.
I'm doing my LM3 w/a 95 Sport forks right now.
Remember the EV-Eldo that was done up at MI, way back time machine.
Offline ccoli
  • What? Me Worry?
« Reply #3 on: September 01, 2015, 08:48:47 PM »
I'm planning on it. Rob Dentico was going to make up some stem but got busy. I talked to a Chicago guzzi guy who did something similar but just ordered a bushing to put the smaller diameter stem into the larger diameter hole.
I'm still busy getting my sidecar back together and moving a tool shed.
Retirement is taking up all my time.
I'm also trying to fit a 98 EV front end on my SPII.
Wisconsin MGNOC Rep
Offline mtiberio
    • TiberioRacing
« Reply #4 on: September 02, 2015, 09:36:45 AM »
greg field did it while he was at moto international. IIRC, the triple clamps had a bunch less offset than the stock loop triple clamps. That way the top of the forks and their damping adjusters actually nestled in the scooped out area along side the ignition switch spot (I believe he had a police cluster, so perhaps he hadn't done the switch mod, but if you think early ambo cluster, you'll know what I mean). He must have had custom mounts for the instrument cluster, as the normal forward mounts into the top of the fork caps was not there.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
« Reply #5 on: September 02, 2015, 11:27:25 AM »
Here's GFs..
Seems like I remember him telling how on here, but a quick search didn't find it. I'm packing for Ohio, no time to research..
« Last Edit: September 02, 2015, 11:34:26 AM by Chuck in Indiana »
Online fotoguzzi
« Reply #6 on: September 02, 2015, 08:44:23 PM »
Here's GFs..
Those are not EV forks, they come from a spine frame..
BUMP, anyone else? EV  forks on a LOopFrame..
