Author Topic: 1998 Bassa parts list and wiring diagram  (Read 5031 times)
Offline jmac851
« on: September 02, 2015, 09:20:06 PM »
Does anyone know where I can find a wiring diagram and a parts list for a 1998 Bassa?  The 1998 had the P8 ECU with a PF3 tps.
1967 V700
1969 Ambassador
1984 Cal 2
1996 Cal 1100
1998 EV 1100
2006 Breva 1100
1994 BMW R1100RS
Offline twhitaker
Re: 1998 Bassa parts list and wiring diagram
« Reply #1 on: September 02, 2015, 09:25:28 PM »
The wiring diagram can be downloaded from here.
http://www.thisoldtractor.com/guzzi007/sportissimo.html
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline jmac851
« Reply #2 on: September 02, 2015, 09:33:58 PM »
Greg doesn't have it on his website. He has the later model and only the California Special. Not the same.
1967 V700
1969 Ambassador
1984 Cal 2
1996 Cal 1100
1998 EV 1100
2006 Breva 1100
1994 BMW R1100RS
Online pehayes
« Reply #3 on: September 02, 2015, 09:35:38 PM »
Odd.  The Bassa didn't arrive until 1999 and I think it already had the upgraded, smaller cpu.  I have a DVD with the parts diagram. What are you after?  Yes, you can download the wire plans as shown above, but there are lots of subtle variations around this time.
Online pehayes
« Reply #4 on: September 02, 2015, 09:37:13 PM »
I have the 1998 EV.  It does not exactly match any wire plan in print.  Part of it matches the 1998-EV plan and part of it matches the 1997 1100-i plan.  You'll just have to sort through.
« Reply #5 on: September 02, 2015, 09:39:35 PM »
« Reply #6 on: September 02, 2015, 10:05:09 PM »
As Patrick says, it's a hybrid
This document is handy to understand the P8
http://www.dpguzzi.com/efiman.pdf
Offline jmac851
« Reply #7 on: September 03, 2015, 08:21:27 AM »
Patrick,  It's a 1998 Bassa with a build date of 1-1998 on the fork tag.  It is not the same as the 1999 and later.  Do a google search and you can clearly see the difference.  There are pictures all over.  There is one being parted out on EBAY. They are 1998.
As for the instruction books, etc, is there any written material from Guzzi that uses the word Bassa? Everything I can find says California.  (ie: stone, special, aluminum, etc.
1967 V700
1969 Ambassador
1984 Cal 2
1996 Cal 1100
1998 EV 1100
2006 Breva 1100
1994 BMW R1100RS
Offline Mark West
« Reply #8 on: September 03, 2015, 12:18:19 PM »
Well. That's news to me. Had no idea there were Bassa's with P8 CPU's.
I suspect it would be very close to the 98 EV for wiring and for parts with the exception of bodywork and a few other bits.
Good Luck.
Mark West
Hollister, CA
MGNOC L-752
« Reply #9 on: September 03, 2015, 01:24:06 PM »
That's the first '98 Bassa I've heard of too : snapping suspenders..
Offline guzziownr
« Reply #10 on: September 03, 2015, 05:08:29 PM »
« Reply #11 on: September 03, 2015, 05:55:40 PM »
can you share some pics of the '98 Bassa?
here's the '99 I had, a lovely bike!
Offline jmac851
« Reply #12 on: September 03, 2015, 07:09:01 PM »
Thanks for all of the info on the Bassa. The one I bought did not have the side covers but had one of the special brackets those covers require. Also, the tail light had been changed to an EV light. The po sold off most of the good stuff after the wiring harness shorted out and burned.  I'll just make it an EV 1100 and be done with it.
1967 V700
1969 Ambassador
1984 Cal 2
1996 Cal 1100
1998 EV 1100
2006 Breva 1100
1994 BMW R1100RS
« Reply #13 on: September 03, 2015, 07:16:54 PM »
That's OK, I mean no offense.. we all know the factory did some odd things.. and nothing wrong with your bike whatever it is.. do you have tubeless rims? that's the best advantage the EV and Bassa had over the Jackal and Big Twin Stone..
do you need a wiring harness?
« Last Edit: September 03, 2015, 07:17:32 PM by fotoguzzi »
Offline rboe
« Reply #14 on: September 03, 2015, 10:06:27 PM »
Has the tubeless rims.
Phoenix, AZ
2008 Honda XR650L
2012 Griso SE
2013 Honda CB1100
Offline rboe
« Reply #15 on: September 03, 2015, 10:27:32 PM »
Google search on Moto Guzzi Bassa gives this site: http://www.mgcn.nl/html/bassa.htm
The photo matches the one on page 274 of Mario Colombo's Moto Guzzi, The complete history from 1921. He does not use the term "Bassa" but calls it the California Special, starting with 1998 model year..
Just a couple data points.
Phoenix, AZ
2008 Honda XR650L
2012 Griso SE
2013 Honda CB1100
Offline Rich A
« Reply #16 on: September 03, 2015, 10:31:29 PM »
Thanks for all of the info on the Bassa.....I'll just make it an EV 1100 and be done with it.
In addition to the sidecovers, the rear fender is quite different. The wiring harness will take some fiddling, but it really isn't too bad. I had to replace one on a Jackal.
Rich A
« Reply #17 on: September 04, 2015, 03:03:46 AM »
To prevent it burning out again add a 40 Amp in-line fuse where the ignition switch feed leaves the battery, every Guzzi should have one.
It will only blow if there is a short.
What parts do you need?
The sidecovers look like quite a different shape from an EV
« Last Edit: September 04, 2015, 03:12:32 AM by Kiwi_Roy »
