Author Topic: What the heck is on my pistons?  (Read 6239 times)
Offline SmithSwede
  • I don't want a pickle
« on: September 06, 2015, 10:23:12 PM »
Ok, here's a photo of various parts for Guzzi V7 Stone.  Check out the pistons. Yes--cool dished out tops in the Heron style.
But what are those black side panels on the piston skirt?
http://search.yahoo.com/search?rewrite=72&.tsrc=apple&first=1&p=moto+guzzi+v7+engine&pintl=en&pcarrier=AT%26T&pmcc=310&pmnc=410&fr=onesearchnew&tsrc=apple
« Last Edit: September 06, 2015, 10:23:54 PM by SmithSwede »
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Re: What the heck is on my pistons?
« Reply #1 on: September 06, 2015, 10:27:55 PM »
Link only takes me to a search engine.
My guess is you mean the Teflon coating on the truncated skirts. It's there to reduce friction.
« Reply #2 on: September 06, 2015, 10:42:52 PM »
Yes, it's not a 70's shovelhead, things have improved w/technology
Offline Idontwantapickle
« Reply #3 on: September 06, 2015, 11:08:42 PM »
Snort!
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
« Reply #4 on: September 07, 2015, 04:03:08 AM »
I think it is called DLC for diamond like coating. A hard ceramic like coating to reduce wear and friction.
« Reply #5 on: September 07, 2015, 04:04:46 AM »
(Sigh!) No, it's not. It's something entirely different.
« Reply #6 on: September 07, 2015, 04:39:46 AM »
See second reply. It's Teflon.
Offline Dukedesmo
« Reply #7 on: September 07, 2015, 04:48:09 AM »
In which case don't use Italian oil, my Mrs bought an expensive frying pan which I used to fry stuff in Olive oil and the Teflon flaked off...   :thewife:
Le Mans II
Ducati 916
Ducati M900
Rough Edge racing
« Reply #8 on: September 07, 2015, 06:33:36 AM »
 Some high performance V8 car pistons have the black coating on the skirts....It's to reduce friction and I don't believe it Teflon...
« Reply #9 on: September 07, 2015, 07:19:55 AM »
I hope it wasn't put on by the company that hard faces the lifters.
Bill Havins
« Reply #10 on: September 07, 2015, 07:32:18 AM »
[insert rimshot]  You're bad, Steve!
« Reply #11 on: September 07, 2015, 08:20:56 AM »
It's used on the big blocks too, has been since mid way through the V11 series.
« Reply #12 on: September 07, 2015, 08:54:18 AM »
Been used on two stroke snowmobiles without issue for over 12 years
« Reply #13 on: September 07, 2015, 09:28:20 AM »
 :weiner:
Been on 2 stroke motorcycles for 40 years. They use it not only on the pistons, but also would often put it on the rings where they rub the pistons.
Offline SmithSwede
« Reply #14 on: September 07, 2015, 10:51:14 AM »
Thanks.  Very interesting.  I had no idea they did that.
Does Moto Guzzi keep this a secret to avoiding offending the Luddites?
« Reply #15 on: September 07, 2015, 12:03:17 PM »
It is so common to do, why/how would it be a secret?
