Author Topic: Anyone want to try a single lambda Stelvio map?  (Read 3615 times)
Offline Xlratr
« on: September 11, 2015, 03:28:49 PM »
After rollerising my 2 lambda Stelvio, I've been logging and adjusting the mapping to fit. Even if I do say so myself, I think it runs very strong!. :-). If anyone wants to try it they're welcome.
Then I started thinking it might be fun to take those values and integrate them into a single lambda framework. (The single Lambda map is set up a bit differently, and some of the tables have a different logic, but there are very many reference points in the various tables on which to base the retro fitting). It started out as a kind of academic exercise, but now I have a full single lambda map, but no bike to test it on. I think it's logically very solid, so if anybody with Guzzidiag experience wants to try it, just let me know. Send me a PM (with your emaill).
« Last Edit: September 12, 2015, 06:01:11 PM by Xlratr »
Re: Anyone want to try a single lambda Stelvio map?
« Reply #1 on: September 11, 2015, 06:12:16 PM »
Looks like everyone with a single lambda Stelvio has stuck it on the Bay of Fleas because it's got flat tappets....    :rolleyes: :boozing:
Offline Xlratr
« Reply #2 on: September 11, 2015, 08:35:17 PM »
« Reply #3 on: September 12, 2015, 02:14:17 AM »
I dunno, but it's awful quiet in here..........
Offline Xlratr
« Reply #4 on: September 12, 2015, 06:21:08 AM »
Offline brlawson
« Reply #5 on: September 12, 2015, 08:37:38 AM »
I do have the single sensor version with flat tappets and have a roller kit coming but I have the full power commander setup with autotune. It ran like a hot pig when I got the bike and know it runs as well as it possibly could. I am really not sure what to expect in as to how different the engine will run when converted or if the autotune will be enough to over come the difference which I doubt since it just makes fine adjustments and is not designed to work miracles. I imagine that some change will need to be made at the base level. Your map may be a good starting point.
Also, I have no intention of selling my 8v as it has supplied many miles of smiles and has never left me stranded. I lived through the Hydro fiasco and still have that one too. It's rock solid. At least Guzzi provides the means to make things right.
B. Lawson
Madison, AL
'72 Suzuki Titan 500
'77 Yamaha RD400
'79 BMW R/65
'03 California Titanium
'10 Stelvio ABS
2000 v11 Sport
Offline Xlratr
« Reply #6 on: September 12, 2015, 12:22:13 PM »
... I am really not sure what to expect in as to how different the engine will run when converted or if the autotune will be enough to over come the difference which I doubt since it just makes fine adjustments and is not designed to work miracles.
I've never used a PC/AT setup, but from what I understand, and if it works as claimed, it should easily be able to compensate for the differences required in mapping after a roller conversion. I think the problem with the single lambda model though, is that even the Auto Tune is blind to what's happening on the right cylinder. And I don't t think the factory delta mapping is all that great.
Plus, the PC/AT doesn't have any influence on ignition.
Offline WitchCityGuzzi
« Reply #7 on: September 12, 2015, 07:29:43 PM »
My 09 has been rollerized. I'll try your map!
Doug
2016 V7II Stornello
2011 Griso SE
2009 Stelvio
2004 Ballabio
1979 V1000 Cafe
1970 Ambassador
1966 Stornello Sport
1967 Aermacchi 250SS Sprint
Offline Xlratr
« Reply #8 on: September 13, 2015, 03:52:17 AM »
Doug
Great! Doug, let me have a PM with your email and I'll send it to you.
PS: just want to restate, it's completely untested and just built on working backwards from known values. It should work, but you'll be the first to know!  :thumb:
