Author Topic: Advice recommended: Moto Guzzi Transmission Shop  (Read 5219 times)
Offline NCAmother
« on: September 14, 2015, 06:55:27 PM »
I have a 75 850T transmission that I rebuilt, unfortunately I was getting a lot of "false" neutrals on the work bench.  I sent the transmission to Charley Cole, unfortunately he is very sick and doesn't have the strength to do this job.  Could anyone recommend a good transmission shop that specializes in Guzzi's?  I've asked Cycle Garden Motos and Ed Millich (both in California, my home state), but their hourly prices are around $125.  Any advice would be appreciated :)
Howdy
Online Chuck in Indiana
Re: Advice recommended: Moto Guzzi Transmission Shop
« Reply #1 on: September 14, 2015, 07:05:52 PM »
First.. you *will* get false neutrals on the bench.. if you went by Pete's shimming tutorial, it's probably fine. It's not rocket science.  :smiley:
« Reply #2 on: September 14, 2015, 07:17:58 PM »
When shifting on the bench have you a.) installed the shift drum detente?  b.) Are you turning one or other of the shafts as you try to shift? c.) have you tightened down the input and output shaft nuts?
Offline NCAmother
« Reply #3 on: September 14, 2015, 07:32:04 PM »
Hi Pete, yes the shift detente is in place, and I am turning the output shaft when I shift by hand.  The only thing I changed were all the bearings, and shimmed the drum.  Thanks guys, I didn't know shifts in 'false' neutral were common on the bench.  Also, sometimes upshifting and down shifting is slightly tight when shifting by hand, I've read Pete and John's tech advice several times on This Old Tractor
Howdy
Offline arveno
    • ddleathers.com
« Reply #4 on: September 14, 2015, 07:41:30 PM »
nunzio
« Reply #5 on: September 14, 2015, 07:49:58 PM »
http://www.motoguzziclassics.com/
'nuff said.
+1
You need to call him...he's not much of a Email guy.....Alan
Offline Mike Harper
    • harpermoto.com
« Reply #6 on: September 14, 2015, 07:54:15 PM »
We rebuild 75-100 transmissions and rear drives a year and our shop rate is $85 an hour.  Unless there are serious unknown issues 4 hrs should be max amount of time.  Once we have it we do a tear down and inspection and call with and an estimate.  If you decide not to proceed then that's up to you.
Lots of folks on here have rebuilt parts from us.  Try giving us a call 816-697-3411
Mike
« Last Edit: September 15, 2015, 05:39:43 PM by Mike Harper »
Offline guzzibob
« Reply #7 on: September 16, 2015, 01:12:14 AM »
When it comes to Guzzi trannys, you can do no better than Sean Fader, aka RTL Moto in Santa Ana, CA
http://www.rtlmoto.com/      714-501-4188
I had my tranny rebuilt at one point by Cycle Garden, then again by Sean. No comparison, really. PM me for details if you wish. Used to have false neutrals all over the place unless I was really positive about shifting. Now, it just doesn't happen, ever. Its been 70, 000 miles since Sean worked on it, still perfect. Best shifting Guzzi 5 speed, ever, IMHO.
Bob Dickman
Burbank CA
91 1000S
78 850T3FB
07 Norge
Lifetime MGNOC/AMA
« Reply #8 on: September 16, 2015, 06:20:59 AM »
This. Sean *is* one of the best mechanics I've ever met. He used to work for Mark at MGC, and I've seen a lot of his work.
Offline NCAmother
« Reply #9 on: September 16, 2015, 10:46:06 AM »
Thanks for the advice everyone!  I just got a PM from JoeW the day I put up the post, I think I'm going with him.  I'll be having him do the ElDorado shifting drum swap on the 850T transmission.
Nate
Howdy
Offline groundhog105
« Reply #10 on: September 16, 2015, 08:01:16 PM »
Another plus for Sean Fader especially if your on this end of the country. He is excellent mechanic and fair in his pricing.
