Author Topic: Press regulator needed ASAP for a '94 Daytona!  (Read 2459 times)
« on: September 16, 2015, 12:59:38 PM »
A good friend has a 1994 Daytona and he thinks he has a Press regulator issue (he thinks...)
The little brass nipple on the bottom is dripping gas. He assumes the regulator is bad.
Anyone have one for sale?  Guzzi part number # 30112700 Thanks in advance.
Best regards
JJ Cerilli
john.cerilli@yahoo.com
(510) 377-5575
Re: Press regulator needed ASAP for a '94 Daytona!
« Reply #1 on: September 16, 2015, 01:23:06 PM »
Yes the diaphragm is leaking, perhaps cracked with age.
The good news is most regulators seem to operate ~ 45 psig so you should be able to lay hands on one at a car parts store.
If it's not leaking too bad you might be able to get home by just putting a hose on the nipple and running into a container, don't block it off, that would cause over pressure to the injectors.
BTW some earlier manuals show the nipple connected to the manifold, I think at one time the regulators were set for a lower pressure and the connection varied the pressure to match manifold pressure. At 45 psig the injectors are operating in what's known as choked flow and not effected by manifold pressure.
The pressure setting is not critical to double the flow you have to square the pressure so even 5 psi makes little difference but I think 45 psi is common regulator setting.
The Efiman document that describes the early fuel injection systems shows it connected to the manifold, ignore that, it must have been a very early idea. Further into the manual they talk about the pump putting out 44 psi (regulator setting)
http://www.dpguzzi.com/efiman.pdf
this gives a very good description of the P8 regulator and most of it also applies to the later 15M type
Cheers
Roy
« Last Edit: September 16, 2015, 05:18:52 PM by Kiwi_Roy »
« Reply #2 on: September 16, 2015, 03:46:47 PM »
Thanks Kiwi-Roy! :cool:
I copied and sent my response to my friend (who is not on wildguzzi).
Your Guzzisti wisdom is much appreciated! I will let you know the progress!
Best regards,
JJ Cerilli
Scottsdale, AZ
« Reply #3 on: September 18, 2015, 07:34:16 AM »
To Kiwi-Roy (from my friend with the Daytona...)
"I thank you for the advice. That is what I was thinking. I used an SD Sorensen 800-550 regulator and it is purring like a kitten. 44 psi same mounting and looks almost identical to original..
Thanks again"
JJ Cerilli
Scottsdale, AZ
