Author Topic: Telefix fork brace...or Tarozzi.  (Read 5764 times)
Offline Stevex
« on: September 21, 2015, 12:43:45 PM »
I'm trying to source a Telefix fork brace for a LM2; I've talked to Telefix in Germany and they have no stock and no longer manufacture one for the LM2.
Does anyone know where I could source one?
An internet search brings up a company in Sylmar, CA called Spec II but there is no email contact info. They include the LM2 in their list of models that they supply the fork brace for; has anyone had dealings with them?
As an alternative, has anyone fitted a Tarozzi fork brace to an old Guzzi; how does it perform?
The reason I'm asking...on a previous thread I was looking for advice on why my front brake lever came back further than normal on some occasions on my de-linked system. At the time I couldn't diagnose the problem.
This w/e I took my LM2 out for a ride and the brakes were fine until I hit a series of bumps in the road; the front lever then took a couple of pulls until they performed normally again. This happened a couple of times after hitting bumps and I'm sure the forks are twisting slightly and pushing the pistons back into the calipers.
« Last Edit: September 21, 2015, 12:55:36 PM by Stevex »
Re: Telefix fork brace.
« Reply #1 on: September 21, 2015, 12:51:53 PM »
My Mille had a Tarozzi fork brace on it when I bought it.  I have not ridden the bike without it, but it's quite stable when pushed in turns to the point of scraping things, even on moderately bumpy roads.
Offline Kent in Upstate NY
Re: Telefix fork brace...or Tarozzi.
« Reply #2 on: September 21, 2015, 01:25:39 PM »
Offline dan_s
    • http://www.world-designs.co.uk/forum/member.php?u=128
« Reply #3 on: September 21, 2015, 01:28:00 PM »
Tarozzi braces are finished very badly. Mine didn't fit on the fork, I ground it to measure but it wasn't good enough and it cracked one slider. Had to give it to a machinist to make it usable. If you buy a Traozzi brace, be extra careful before you install it.
Offline Curtis Harper
    • Harpers Moto Guzzi
« Reply #4 on: September 21, 2015, 02:04:52 PM »
Spec-II number used to be 818-837-1313 I also have 818-504-6364
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
Offline NCAmother
« Reply #5 on: September 21, 2015, 02:19:34 PM »
Howdy
« Reply #6 on: September 21, 2015, 03:10:39 PM »
I've not been able to find a fork brace for my 98 EV.
Offline Oldrat
  • Brian
« Reply #7 on: September 21, 2015, 03:27:55 PM »
Try Nigel at NBS
He has polished ally fork braces for old Tontis
http://www.motorcycleservicing.co.uk/moto_guzzi_products.htm
Got one myself.
1976 'Zagato' Guzzi cafe racer
1978 Black & Gold, Coburn & Hughes Mk2 Le Mans
2001 Ducati 996R
2017 BMW R1200 GSA
Offline ejs
« Reply #8 on: September 21, 2015, 04:39:42 PM »
 :popcorn:      GU03436600
 :popcorn:
California EV 1999
« Reply #9 on: September 21, 2015, 05:05:26 PM »
 :popcorn:
Is that the stock one that is on my current bike?
Offline Stevex
« Reply #10 on: January 10, 2016, 01:30:26 PM »
Finally opted for the NBS fork brace, mainly because it was the only metallic one I could find available.
Unfortunately it is cast in aluminium before being machined, so there were quite a few pock marks in the finished item due to
air bubbles.
Who ever had decided to polish it also went over board, because even the stainless bolt socket heads on the fork clamps had been rounded on places, as well as one clamp in the same area being worn down by the polishing wheel!
I decided to fill all the pock marks with JB Weld and built the worn areas back up with the same.
I then needed the top of the clamps machining to allow the dust seals to sit properly and be positively retained in place.
Finally some primer and a finishing coat of satin black.
A lot of work considering, but I'm happy with the result.
« Reply #11 on: January 10, 2016, 02:36:52 PM »
funny how replacing my rear tire helped to stabilize my fork.
 :laugh:
