Norge Aux Driving Light?
Topic: Norge Aux Driving Light? (Read 1842 times)
TobyJug
Gosling
September 24, 2015, 10:05:27 PM »
I was thinking about putting some of these Denali mini aux driving lights on my front fender ..
http://www.aviciouscycle.ca/Mainpages/productpage.aspx?product=5172
until I took one of the screws out to see what size it is and it's smaller than either the 5 or 6mm bolts supplied with the fender mounting kit. Has anyone mounted any aux driving lights on their fenders? Is it okay?
Jug
2014 Norge GT 8V
Re: Norge Aux Driving Light?
Reply #1 on:
September 25, 2015, 12:28:41 AM »
I put a driving lamp under the front of the fairing. Lights attached to the fender will bounce as the bike encounters bumps and so on. The lamps might also put stresses on the plastics from the constant up and down vibrations and create cracks.
If you run a search you should come up with some solutions that might work for you. I have found that the light s on the Norge are very good and over driving them takes quite a bit. Nevertheless, several of us have mounted additional lighting.
Here is a link but others have done some nice work, check around.
http://wildguzzi.com/forum/index.php?topic=76959.0
Last Edit: September 25, 2015, 12:30:49 AM by Norge Pilot
Wayne Orwig
Reply #2 on:
September 25, 2015, 07:23:00 AM »
$315 for only a 5 watt LED light?
TobyJug
Gosling
Reply #3 on:
September 26, 2015, 12:48:49 AM »
Thanks Norge Pilot - some good points there. I'm looking to be more visible so the further the lights are apart, the better. And I'd rather not screw into the tupperware. Back to the drawing board ...
2014 Norge GT 8V
