Author Topic: Centauro rear drive leak  (Read 2519 times)
Offline Daleroso
« on: September 28, 2015, 05:54:19 PM »
 Beginning a rear drive leak (bottom onto the rim) from my 18 yr old rear drive seal. How big of a deal is it to get to & change? Airhead Beemers weren't bad. Thanks in advance for feedback!
Offline Daleroso
Re: Centauro rear drive leak
« Reply #1 on: September 28, 2015, 06:00:18 PM »
« Reply #2 on: September 28, 2015, 06:10:32 PM »
If it's the "big seal", it will be easy.  You won't even have to remove the bevel box from the bike.
If it's the "little seal" that's inside the box, disassembly will be needed.
« Reply #3 on: September 28, 2015, 06:10:50 PM »
Bout like a BMW, pull off wheel, it's right there. Oil filter cup is bout right size to tap it in.
« Reply #4 on: September 28, 2015, 06:54:42 PM »
It's probably time to change it, but Centauros benefit from a rear drive burp. It's not vented, ya know. Get it hot and loosen the filler cap. See if that stops it. Many times it does.
Offline Daleroso
« Reply #5 on: September 29, 2015, 07:42:55 AM »
Thanks! I'll start w/Chuck & go from there.
