Author Topic: Seeking castle nut tool wrench)  (Read 8526 times)
Offline Rolf Halvorsen
« on: September 30, 2015, 01:51:04 AM »
Hi
I am working on the final drive of a V11 Sport 2001. The pinjong is locked in position with a castle nut. I seek a tool to open this nut.
Anyone been there - done that - and can tell me which tool they used?
I need also to know the torque when I am to close the nut again.
Rolf
Re: Seeking castle nut tool wrench)
« Reply #1 on: September 30, 2015, 01:59:45 AM »
I got one made by my then tame machinist who has since died. You want I send it to you Rolf?
As for the torque? About a quintillion mile tons!
« Reply #2 on: September 30, 2015, 05:36:04 AM »
Hi Pete
I also have a tame mechanic - so a picture of yours would help.
There must be a professional tool out there!!!!!
If not - I am going to make one - as always top professional.
Let us see if anyone else chimes in.
If nobody except you (and me soon) have this tool - does this mean that nobody hav been there to change the sealing ring or bearings?
Rolf
Offline johnr
« Reply #3 on: September 30, 2015, 07:05:07 AM »
I must be igorint.
Why do you need a special tool for a castle nut? I've always just pulled the split pin and then used an ordinary socket.
Would someone please enlighten me?
New Zealand
« Reply #4 on: September 30, 2015, 08:13:11 AM »
I must be igorint.
He's probably talking about that stupid "special" nut like they used on the front axle of the Centauro.  :rolleyes: No doubt off a WW2 Fiat fighter plane.  :smiley:  They had a barrel full and had to use them somewhere.. just my guess.
« Reply #5 on: September 30, 2015, 08:17:17 AM »
Yeah, I am going to have to change the tires on the Daytona and I was wondering what I was going to do about that nut.
« Reply #6 on: September 30, 2015, 08:33:54 AM »
Many just used vise grips (!) and then put a normal nut on it. I made a simple tool you can borrow if you want. Assuming I can find it, of course.. haven't seen it for a while.  :rolleyes:
« Reply #7 on: September 30, 2015, 08:48:09 AM »
Ah yes, I used a pipe wrench, and replaced with a normal nut.
In this case I suspect the 'special' nut may be required.
Offline motoduck
« Reply #8 on: September 30, 2015, 08:50:54 AM »
I have a special tool that I had made professionally back when I had the dealership.  I don't think an officical tool exists.  I am happy to send it to you as well....
Jeff in Detroit
Jeff Bottrell
Metro Detroit Area
73 Eldo with Steib sidecar
2 V7 Sports (ex Racebikes)
78 Lemans
78 Lemans AHRMA Superbike
Lots of other non MG bikes that don't matter here
If at first you don't succeed, lower your expectations.
Offline John Ulrich
« Reply #9 on: September 30, 2015, 09:18:37 AM »
You must be talking about this one.  I purchased mine from Moto International back in 2001 or so.  They started out cheap and then the price was over $100.  MG Cycle shows them now for $35
Eagan, MN & Scottsdale, AZ
MN MGNOC Rep  L#800
« Reply #10 on: September 30, 2015, 11:54:26 AM »
Nah, the V11 bevelboxes are completely different to the earlier Tonti and early Spiney boxes. They have a weird two part split bearing with rollers and balls to take end thrust on the pinion and the pinion depth is controlled by shims under this bearing assembly between it and the box casting. The whole lot is secured in the box by a huge castellated ring nut that is done up hernia-inducingly tight, (Best bet is to stick some heat info the casting as you're trying to undo it or you'll bust your chuffer-valve getting it undone!) it's much larger and very different from the wheel spindle nuts.
Rolf, I can't post pics on the board at the moment but PM me yer email addy and as soon as I get the chance I'll dig the tool out and take a pic to send you. I have to go to Sydney to pick up a Griso tomorrow so it won't be until Friday at least.
« Reply #11 on: September 30, 2015, 12:49:56 PM »
chuffer-valve
 :smiley: :smiley:
« Reply #12 on: September 30, 2015, 12:58:29 PM »
Thanks John.
http://www.mgcycle.com/index.php?main_page=product_info&cPath=80&products_id=4515
I'll just buy the socket so some future seat sniffer can point out that it's still original.
Offline Jurgen
« Reply #13 on: September 30, 2015, 01:36:57 PM »
Could someone please send a picture of the nut that requires a weird socket like that?
Jurgen
Jurgen
« Reply #14 on: September 30, 2015, 01:42:37 PM »
 It is another one of those great inventions designed to prevent owners from working on their own machines.
 That is the sole purpose of such a nut.
Offline John Ulrich
« Reply #15 on: September 30, 2015, 02:50:25 PM »
Sorry I misread the post .....too early to read and comprehend.  This is for the front axle nut used years ago.  The "castle nut" reference make me think.... front axle nut!
« Last Edit: September 30, 2015, 02:51:23 PM by John Ulrich »
MN MGNOC Rep  L#800
« Reply #16 on: September 30, 2015, 02:55:37 PM »
Ooops....looks like I purchased the last one.
Offline guzziownr
« Reply #17 on: September 30, 2015, 03:00:38 PM »
...and not the same as the one for the one for the CARC swingarm?
Leafman's photo:
« Reply #18 on: September 30, 2015, 04:06:22 PM »
Leafman's photo:
No.
« Reply #19 on: October 01, 2015, 01:40:40 AM »
Hi all
A lot of missunderstanding. The castelated nut I am refering to has part No. 04354900
Only Pete has clearly understood my problem.
https://www.stein-dinse.biz/eliste/index.php
When you open this, on part diagram 2 you will find this nut with a refering number 18.
I NEED THE TOOL
What is out there?
(Pete: I will send you a private mail)
Rolf
« Reply #20 on: October 01, 2015, 01:43:51 AM »
My email has changed since we last conversed. My new n is on the Guzzi Oz website though or PM me.
Offline motoduck
« Reply #21 on: October 01, 2015, 08:19:05 AM »
As I said...I have the tool.  Haven't seen it in a while but am sure I can dig it up.  I had it made at great expense and used it one time on a V11 Lemans.  Not sure where you are located Rolf but if you are Stateside, I am sure I can loan it to you.  I really have no use for it.
Jeff
Jeff Bottrell
Metro Detroit Area
78 Lemans
Offline Mike Tashjian
« Reply #22 on: October 01, 2015, 08:22:30 AM »
I made a wrench for the BMW rear drive I have and used some heat to soften the thread sealer used on the threads.  I used a piece of close fitting pipe with inserts welded into it to fit the slots.  Not hard to make and worked well. I just had to change a seal so no real measuring involved and torque is a mute point with thread sealer slathered on the nut.  Mike
Offline Jurgen
« Reply #23 on: October 01, 2015, 10:58:35 AM »
Leafman's photo:
Thanks for the photo.  Jurgen
Jurgen
kidneb
« Reply #24 on: October 01, 2015, 02:52:03 PM »
Hi all
I NEED THE TOOL
What is out there?
Rolf
That is not quite correct Mr. Halvorsen.
Jeff in Detroit
And he addresses you again today (#21) , not knowing where in the world you are located.
  //Ben
« Reply #25 on: October 01, 2015, 03:33:35 PM »
Yes you are right. I am sorry that I forgot to refer to what MOTODUCK (Jeff) wrote. He was also correct - my error.
I live in Norway so purchase of a tool would be simplier than to borrow one.
Anyonbe else have knowlege of this tool?
Rolf
« Reply #26 on: October 01, 2015, 04:52:01 PM »
I'll try and get a pic off to you today Rolf.
