You'll like the book.Zimmerman is a personal friend.
Is this update for the dry alternator or wet alternator bikes? I believe that the previous updates were different for the two different bikes. Thanks.
Right guys, sorry for the hiatus. Only doing a course at the best film school in the world NFTS. So really exhausted. So took the bike last week and the problem actually was the Lambda sensor. One of them was black with soot apparently. There are 2 attached to the Left and Right exhausts and the one of the right for some reason was faulty. This was cleaned and placed again. Riding ok now.
Hi allSo the problem still continues. But this time I caught it on video. https://www.youtube.com/watch?v=kzlusSPZelMI've taken her to the dealers again. Perhaps its the stepper motor. But let's see.ThanksJay
maintenance resetNew dash is the same as the old one. When you gate the 'Maint' alert when you turn the key on all you have to,do from memory is turn the ignition off, wait for a few seconds and then press the left hand button and hold it down. Now turn the ignition back on and wait for the clocks to go through their dance and the word 'Maint' will appear briefly and then disappear.Release the button, turn the ignition off and then on again and the 'Maint' warning should of disappeared. Sometimes, for no reason I can make out, you need to have the side stand up for it to work. Don't ask me? I only work here!
I bought the bike as a private sale and he apparently serviced the bike at 644 miles. I have the service booklet that confirms this. The dealer today said that he would reset this.
.....Not sure what the torque is supposed to be. For some reason that point is missing from the V7 service manual......
There are two other fittings, but they are just pins in rubber grommets. Don't be afraid to pull on it.
Pull hard.You might rip the rubber grommets or pull them off, but it's okay everyone does it.
Hi, my brand new '13 V7R had EXACTLY the same problem, and the dealer was worse than useless, so was the Guzzi Technician. They fitted a new ECU, it spent the first 4 out of five months I owned it back at the dealer, but they could find nothing wrong. She is now serviced by Baldrick. I tried everything. I even rejected the bike but they claimed they had "no money". In the end, as an experiment, I disconnected the lambdas. Hey presto. It's never done it again. 20k trouble free miles now on the clock. Here's my vid of the bad running... https://m.youtube.com/watch?v=atwqPojoBz8
I would definitely check to ensure that the two rubber boots on the intake manifold are secure and not leaking. And believe it or not, I've seen these screws loosen over time due to vibration, so I now use lock-tite on them.Also check that the mufflers are securely clamped to the exhaust pipes, and that the clamps on both ends of the cross-over pipe are secure. It's my understanding that leaks in these areas are common, and they will play havoc with the ECU and fueling.
