Author Topic: AGM battery question, if you run it all the way dead....  (Read 5601 times)
Online bad Chad
« on: October 17, 2015, 04:46:11 PM »
I'm embarrassed to admit, but about a month ago I was tinkering with the B1100, the phone rang, and I left the ignition on for 24hrs.
When I went to start the bike the next day the battery was completely drained, no sounds, even the flashing red security light was gone.
I charged the battery back up at 2amps for 12 hours, and all seemed fine.  However the other day, it didn't have enough juice to turn the motor over.  Did running down to 0 damage the battery?
Re: AGM battery question, if you run it all the way dead....
« Reply #1 on: October 17, 2015, 04:59:29 PM »
 How old is the battery Chad ?
Online Wayne Orwig
« Reply #2 on: October 17, 2015, 05:00:09 PM »
It easily sulfated the plates and damaged it.
If you have a desulfator, you may want to try that.
« Reply #3 on: October 17, 2015, 05:00:58 PM »
Yep .... complete discharge is the worse thing that could happen to agm type battery.
 :cry:
Online bad Chad
« Reply #4 on: October 17, 2015, 05:06:32 PM »
Battery is 14 months old.
Offline jackson
NO longer can ride
« Reply #6 on: October 17, 2015, 05:21:44 PM »
 As Wayne said , it is probably just sulphated since it is that new .
Online bad Chad
« Reply #7 on: October 17, 2015, 05:28:42 PM »
Jackson, it is not an Optima, its a Advanced Gel Matt.
Offline jackson
« Reply #8 on: October 17, 2015, 05:32:50 PM »
I think that you meant to say, "absorbent glass matt".  If you have an AGM (absorbent glass matt) battery, the Optima battery is also the same technology.
Here's the difference; http://www.batterystuff.com/kb/articles/battery-articles/gel-vs-agm.html
So, if you have a Gel cell battery, I think that the party is over for the battery because it's highly likely to be fried and not fixable.  But, if you have an AGM, there is some hope for reviving it.  Hope this helps.
« Last Edit: October 17, 2015, 05:38:59 PM by jackson »
NO longer can ride
« Reply #9 on: October 17, 2015, 07:13:20 PM »
I believe if you work the battery it will be able to restore itself.
If it doesn't have enough grunt to wind the bike over run it down to 12 Volts with the headlight then charge it back up again.
Offline jrt
« Reply #10 on: October 17, 2015, 09:00:59 PM »
I ran down an older AGM into the ground and it never recovered.  Best of luck to you!
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline LeRoy
« Reply #11 on: October 17, 2015, 10:11:16 PM »
Even though it's not an Odyssey battery, if it's an AGM, this may help:
http://www.odysseybattery.com/documents/ProceduretorecoverdeeplydischargedODYSSEY.pdf
LeRoy (Bob Sharp)
Rochester, MI  U.S.A.
'83 1000SP (as of Oct. 15)
« Reply #12 on: October 18, 2015, 06:33:13 AM »
The link refers to smart chargers confused as to whether a battery is 6V or 12V, I have seen this quite often with smart chargers.
Could this be the problem, the battery was so low your charger couldn't recognize it?
If you have an old 12V wall wort from a printer or something, they make great trickle chargers, too dumb to care if the battery has 3 or 6 cells.
« Last Edit: October 18, 2015, 06:39:42 AM by Kiwi_Roy »
Offline Steph
  • Cali Stone/ LM3
« Reply #13 on: October 18, 2015, 06:47:34 AM »
2amps is not a lot. I would charge it again until you have 12.8 volts at rest.
Then maybe look a parasitic drains that runs you battery down
Offline Dean Rose
    • Twin Valley Riders
« Reply #14 on: October 18, 2015, 07:16:05 AM »
On the new bikes the electronics drain the battery down, maybe Wayne or one you Electrical Wizards can adviise on maybe pulling a fuse when not riding the bike to prevent this.
Dean
Magnolia '02 EV
Sophia '06 Breva 1100
Online bad Chad
« Reply #15 on: October 18, 2015, 07:43:38 AM »
Thanks all.   Yes Jackson, you are right, it is a AGM.   Seems to be holding fine, I'll monitor it and see what happens over the next couple weeks.
Offline jackson
« Reply #16 on: October 18, 2015, 08:09:25 AM »
 :thumb: :thumb:
I would check the voltage reading at the battery every day and if it's still holding where it should be after a week, I think you'll be good to go.
I once had an Optima that went totally dead due to leaving the ignition switch on.  The local battery shop told me that it was ready for the scrap pile but I read an article about how deep cycle batteries can be saved and I was able to resuscitate it.  It lasted another 3 years.
Glad to hear that you got it going.
NO longer can ride
« Reply #17 on: October 18, 2015, 01:08:33 PM »
The battery is toast. Trying to desulfate an AGM is an effort in futility.
Say the battery appears to work OK for a few weeks, you gonna trust it for a longer trip only to have it fail 40 miles for the nearest hodunk town?
What's a new battery cost, same as an oil change and a few tanks of fuel? Every time you ride and turn it off you'll be wondering if it will start.
« Reply #18 on: October 18, 2015, 02:30:24 PM »
Exactly.
Sorry.
« Reply #19 on: October 18, 2015, 02:38:26 PM »
Exactly.
Sorry.
 So... what type of toaster did you use to achieve such perfection ? Butter , margarine , marmalade ? C'mon Pennie  :grin:
« Reply #20 on: October 18, 2015, 03:54:18 PM »
T-FAL!
