Author Topic: Time for fold down arm rests for Norge tail box  (Read 3608 times)
« on: November 03, 2015, 05:36:40 PM »
I've been told that if the Norge had some arm rests for the co-pilot that I'd realize some form of reward. I thought rather than just a tube of sorts going through the box with arm rests on either side that swing down, perhaps an additional support that folds down from underneath the arm rest to hit the top of the side bags making the arm rests solid feeling.
There is a back pad which means the cross support could be exterior to the box.
Any ideas?
Re: Time for fold down arm rests for Norge tail box
« Reply #1 on: November 03, 2015, 06:56:50 PM »
I think you'll find that you need to fabricate something that's attached to the bike, rather than the top box.
« Reply #2 on: November 03, 2015, 07:14:06 PM »
Don't know about that, not much different than tail box for Hondas.
http://m.ebay.com/itm/400682902946?_mwBanner=1
Just need some brackets. The tail box is wide enough.
With mods, those might even work. I'll see if I can find some at the local dealer to look at.
This would work too and mounted to the box lower, would come off when top box was removed.  Getting closer.
http://www.jpcycles.com/product/179-284
« Last Edit: November 03, 2015, 07:21:00 PM by Norge Pilot »
Offline Demar
« Reply #3 on: November 03, 2015, 07:39:41 PM »
Instead of folding (pivoting) the arms could be telescoping. Could be as simple as fastening two pvc tubes to the top box sides (there is ample length there). After the pillion gets on they could extend the arms forward from the fore-aft fixed tube on the top box. Two smaller tubes on each side will prevent arm rotation (think over-under shotgun barrels) or an inner tube with pin riding in a bottom slot in the outer tube will do the same thing.
« Last Edit: November 03, 2015, 07:41:18 PM by Demar »
2012 MG Stelvio NTX
2010 Bonneville T100
1953 Galletto 175
« Reply #4 on: November 03, 2015, 07:46:19 PM »
Now that might work. I like the telescoping idea. I have some aluminum rectanguar tubing of two sizes that wouldbtelwscope one inside the other. A decent bracket and voila.
Gonna try that, thanks so much. The flats of the rect tubing will be good for mounting a pad. Could use abs sheet with some foam on top. Hot diggity.
Online PJPR01
« Reply #5 on: November 03, 2015, 07:50:52 PM »
I think you're doing yourself a disservice Pilot...let me explain.
The only 2 places your woman's arms should be while riding are either around you or holding onto the bikes curved rear handles.  Giving her an arm rest as a 3rd option is going to remove all that loving you should be getting while riding.  I wouldn't do it!!
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline Demar
« Reply #6 on: November 03, 2015, 07:55:02 PM »
It sounds from his description there might be a strong incentive to provide the arms.  :popcorn:
You might be able to tap the inner aluminum square tube enough to screw in a nylon tipped ball plunger so when the inner tube is fully extended the ball pops up to provide a small resistance to collapsing back into the outer tube. A good push back on the armrest should overcome the plunger ball and let the inner tube retract. Just a thought.
Shoot.... you could even build in a cup holder into the end of one arm.
« Last Edit: November 03, 2015, 08:01:02 PM by Demar »
2012 MG Stelvio NTX
1953 Galletto 175
« Reply #7 on: November 03, 2015, 08:53:54 PM »
Yes, the incentive makes this worthwhile   :wink:
I'll give those ideas a shot, nice to have it better than just good enough. Pics as soon as I get a working setup made.
Offline Gootsz
« Reply #8 on: November 05, 2015, 08:44:59 AM »
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
THERE ARE NO WINNERS IN ROOM FULL OF LOSERS
« Reply #9 on: November 05, 2015, 08:51:32 AM »
Duct tape.
« Reply #10 on: November 05, 2015, 10:45:35 AM »
Duct tape.
Sorry, I like mine functional. Also, right hand doesn't have a name. :wink:
« Last Edit: November 05, 2015, 10:51:04 AM by Norge Pilot »
« Reply #11 on: November 05, 2015, 10:55:40 AM »
not fold down but.
http://www.motorcyclereararmrest.com/index.html
Micky
Those look good too just a little bulky and shiny for the Norge. They do look well made.
Offline travelingbyguzzi
  • God hates a coward
« Reply #12 on: November 05, 2015, 01:41:53 PM »
I see a revolving door situation, Norge Pilot.
After you install acceptable armrests and receive your 'reward', uninstall until further reward promises are made.....
Bill Lovelady      is
Eskimo Spy
73 Eldorado
80 Sp
85 Cal II
97 1100Sport
08 1200 Sport AKA:Sweet Leaf
