Author Topic: VDSTS Question  (Read 2138 times)
VDSTS Question
« on: November 09, 2015, 04:29:17 AM »
Situation:  I have a copy of VDSTS I have used in the past only to reset the TPS after balancing TBs.  Recently, I noticed my 1200 Sport 2v wanted to hang at high idle (1500-1600rpm), but only when the outside air temp was in the mid to high 40s (F).  Once into the 50s, idle went back to normal, with no further issues.  I'm thinking the ECU may be receiving an incorrect reading from either the air temp sensor or engine temp sensor, causing it to idle higher than normal (assuming that is how the map is set up)
Question:  Assuming the bike had been sitting in a cold garage overnight and not been started, would/should the garage air temperature be the same or very close to that shown on the VDSTS gauges screen for engine temperature?  And if the two temperatures are quite a bit apart, would this indicate that the engine temperature sensor (or perhaps the air temp sensor in the airbox) is defective and should be replaced?
Offline molly
Re: VDSTS Question
« Reply #1 on: November 09, 2015, 05:16:06 AM »
I can only tell you what happens with Guzzidiag. If  the bike is stood overnight the readings for the air temp will match the garage temperature. It's a bit more hit and miss with the engine temp but using a probe style thermometer near to the sensor it was pretty close.
« Last Edit: November 09, 2015, 05:27:09 AM by molly »
Dave
Lincolnshire, U.K.
Griso 1100
redrider
Re: VDSTS Question
« Reply #2 on: November 09, 2015, 06:50:41 AM »
Guzziology page 7-53, bottom, lists values for sensors. +32F=9.750Kohms. +50F=5.970Kohms. Quote-"the same values apply to all air, oil and cylinder head temperature sensors used by Moto Guzzi".
Re: VDSTS Question
« Reply #3 on: November 09, 2015, 08:36:50 AM »
Generally speaking they are going to read the same garage temp.
But they are not precision calibrated instruments. Don't expect an exact match.
Re: VDSTS Question
« Reply #4 on: November 09, 2015, 10:39:19 AM »
Thanks, guys, for the good info.
Bob
